Toyota Forum Reorganization #776003 12/30/06 04:39 PM
little_joe Offline OP
Former Admin
Due to the similarities between generations of Toyota 4WDs, it makes sense to consolidate the Toyota forums based on the engine/suspension configurations. Therefore, we will be restructuring the forums as follows:
All mini trucks and 4Runners with 20R, 22R, 3VZE V6 with either leaf-spring or torsion bar front suspension will be in the Early Toyota forum.
All Tacomas, 4Runners, and FJ Cruisers with coil-spring front suspensions and 2.7L 4-cylinders, 3.4L V6, 4.0L V6, and V8 4Runners will be in the Tacoma/4Runner/FJ Cruiser Forum.
All full-size Toyota rigs will be in the Full Size forum. This includes T100, Tundra, Sequoia, Land Cruiser, and the Lexus variants (LX and GX).
Archive will remain. We will end up with 4 forums, one of which is the Archive.
Your thoughts are appreciated. After we get some feedback, we'll set a date for implementation.
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Toyota Forum Reorganization [Re: little_joe] #776004 12/30/06 11:09 PM
1
1FastSS Offline
So early mini trucks 1995 and older will be the Early Toyota forum and 1995.5 and newer will be in the other forum?
How about a 3.0 3VZE forum? j/k
Keep up the good work, nice to have a place to ask questions and get answers. <img src="/forums/images/graemlins/kewl.gif" alt="" />
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: Toyota Forum Reorganization [Re: 1FastSS] #776005 12/31/06 02:50 AM
kewlynx Offline
Yep, we decided the breakdown by engine was the most logical, as it crosses over between trucks/Runners and Tacos/Runners, etc. Was gettin' kind of old to refer the Runner section to the early trucks section for the FSM's we have sticky'd. This is mo' betta. <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
Re: Toyota Forum Reorganization [Re: kewlynx] #776006 12/31/06 08:42 PM
bkg Offline
seriously? not a good idea. I predict it's going to fail.
EDIT: I think Joe's original post has the best breakdown possible. And is more consistent with other tried and true forums out there.
Brian K. Gallus
Re: Toyota Forum Reorganization [Re: bkg] #776007 01/02/07 04:50 PM
Red_Chili Offline
Toyota Section Staffer
I wonder where the Chili fits?? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" />
-Bill
Re: Toyota Forum Reorganization [Re: little_joe] #776008 01/03/07 03:50 AM
fourwd1 Offline
Sounds good to me Joe. It may elminate some confusion as to whether a post should be in the Truck or SUV forum.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Toyota Forum Reorganization [Re: bkg] #776009 01/03/07 09:49 AM
kewlynx Offline
It'll work.
That's funny to read that, as I was the one who suggested most of it originally, aside from the big T's.
I have found myself in the past year referring esp Runners to the FSM in the early trucks section (22Rx and 3.0) or to the Taco section (2.7 and 3.4) where we have an FSM sticky'd there too. The T100's also shared this engine to some degree, so it depended on the generation and/or mill folks would have trouble with for their posts.
With just acquiring a 99 4R myself, I'm in the Taco section a lot to ask about particular things, or to look at the FSM link.
Izzall good. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Toyota Forum Reorganization [Re: kewlynx] #776010 01/03/07 03:38 PM
bkg Offline
It'll work.
So where do non-engine related questions go? For people doing engine swaps? For T-100 folks who have 3.0's and 3.4's?
The engine is an attribute of a vehicle... defining the forum based on an attribute, rather than the vehicle itself, especially on an easily and often changed attribute, is going to be ugly.
If someone does a very nice build on an 85 4Runner and it's a well documented and followed thread... it would go in a 22re section, correct? Where does it go when he/she swaps in a 2.7? 3.4? 3.8? 4.0? 4.3? 5.7??? The truck is still an 85 4Runner, but now the thread no longer fits the criteria that you've laid out for where it should go... who moves it?
Basing the forum on the truck, not attributes of the truck, is ultimately what is going to work. Otherwise you'll end up with a mess.
I stand behind Joe's break-down as listed above. Good, healthy organization.
Brian K. Gallus
Re: Toyota Forum Reorganization [Re: bkg] #776011 01/03/07 03:48 PM
Red_Chili Offline
It means I traverse more forums... but that would be the exception rather than the rule. NP.
-Bill
Re: Toyota Forum Reorganization [Re: bkg] #776012 01/03/07 05:25 PM
ErikB Offline
Toyota Moderator
little_joe & kewlynx are in agreement (Brian seems to think they are saying different things?)- basically the minis will be split between '95 and earlier and '96 and later. If you've built a "mutt," then you get to visit more forums. <img src="/forums/images/graemlins/wink.gif" alt="" />
Sounds like T100/Tundra may remain separate from TLC's though, according to the thread in T100/Tundra...
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6433 MB (Peak: 0.7662 MB) Data Comp: Off Server Time: 2026-10-26 09:46:01 UTC
