You are about to find out where the term 'Smiley Post' came from. --- I've been told that if you ask me what time it is, I'll probably tell you how to build a wristwatch! <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
Here goes:
Just about any automotive grease will do for now - but just so you know, not all grease is created equal... when it comes time to replace that boot, you'll want to use something that's rated and approved for bearings (although, if you buy the Mechatech Kit, it comes with 4 individual tubes of grease - one for each boot in the kit). --- As for what to do with it, yes, you just push a good sized glob of it into opening and coat the CV joint as best as you can (not the shaft-end with the smaller band clamp, but the actual joint-end). --- As you drive, some of the grease will get flung back out - but as long as you keep an eye on it, and keep grease in there, it should be OK until you replace the boot.
After going back and looking at the photo that you posted... that's an
INNER Boot -- the outer is located right against the hub, at the other end of the CV, nearer to the tires.
The first link that you posted is for
ONE individual Mechatech Boot (that comes with a tube of grease and a pair of band clamps) - and yes, you could get by with just that one boot... for now -- but, at some point in time, you *will* have to replace another one - and having the full kit makes the job a whole lot easier (not to mention the fact that you'll already have 3 spare boots, grease, and band clamps).
THIS is what's so special about the kit:
Until the Mechatech Boot Kit came along, in order to change a CV Boot, you had to remove the CV shaft - or, at the very least, you had to remove one end of the CV shaft... and it was a very messy job. --- But once the Mechatach Boots came along, thanks to the super-elastic compound that they are made of, it became possible to replace a boot
WITHOUT removing the CV shaft (provided that you have the full kit - without the kit, they have to be installed just like any other CV boot).
The full kit comes with a handy plastic cone and several tubes of lubricant that are used together in conjunction with the elastic quality of the boot to slide the boot over the hub, without having to remove the CV shaft.
Think of it this way:
![[Linked Image]](http://www.independent4x.com/Images/MecatechBOOT.jpg)
Using the cone and the lubricant, the small opening on the top end of that boot can stretch until it is as big as the larger opening on the bottom - and then it pops right back into shape again a-split-second later, once the boot clears the hub... PRESTO! - it's in-place, like magic! --- Then all you have to do is empty the contents of one of the grease tubes, and install the band clamps (the kit even comes with a band clamp tool that's so easy to use that
*I* can do it!)
Plus, the kit also comes with a CD-ROM video that shows you exactly how to do the whole job.
(* Note to self: Look into getting a kick-back from Matt for my testimonial endorsement <img src="/forums/images/graemlins/lol.gif" alt="" /> )
Seriously, until you've replaced a CV Boot to old way, you simply can't appreciate how cool the Mechatech Kit truly is... Like I said; it makes the job so easy, it's like cheating.
Although Mechatech created the kit to make an easy job of replacing an
outer boot, Rubo and I have talked about the
possibility of how the kit could also be used to replace an
inner boot just about as easily. --- We havn't tried it yet, but it seems to us that you could cover the band clamps of the outer boot with some heavy tape (duct, gaffing, etc.) to protect the new Mechatech boot form getting torn, and then just slide it right over the inner, then up the shaft, and BINGO - you're there. --- Naturally, you wouldn't want to do so unless you were mighty-darn sure that the inner joint wasn't contaminated with any sand, mud, etc. - but as far as we can tell, it is possible to do, nonetheless.
As for a link on hubs, before you start shopping for anything, you might want to read this:
http://www.planetisuzoo.com/articles.htm?id=80(* That's about enough typing for now --- Stick a fork in me; I'm done <img src="/forums/images/graemlins/wink.gif" alt="" /> )
HAPPY NEW YEAR! <img src="/forums/images/graemlins/drunk.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
