Re: What is this and is it hard to replace???
[Re: Tygger]
#776191
01/02/07 04:43 AM
In the mean time, what type of grease do I need to keep things lubricated? Do I just paste the grease in to the opening? Just about any grease is better than nothing, but most auto parts stores should be able to give you grease designed for CV joints. If you want a slightly longer-term fix, saran-wrap the joint after you grease it, and zip tie each side -- it sounds half-assed (and is), but it works surprisingly well. Randii
[Re: randii]
#776192
01/03/07 02:11 PM
Thanks for all the info! You guys are awesome!
In the mean time, I think I'll try the syran wrap trick until I have some time to try and fix this correctly. I don't know how long it's been ripped. Should I attempt to clean it before adding more grease? If so, what's the best way to clean the dirt out?
Is the only purpose of the boot to prevent water, dirt, etc. from getting into the cv joints?
Thx again
1997 Isuzu Rodeo S 4WD
[Re: Tygger]
#776193
01/03/07 03:55 PM
Is the only purpose of the boot to prevent water, dirt, etc. from getting into the cv joints? Pretty much. Basically it's to keep the grease in the joint and the muck out of it. Richard <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: Tygger]
#776194
01/03/07 08:07 PM
DO NOT LET THIS SCARE YOU! I had the same thing happen and printed the instructions with pictures from this website. The first one took about four hours, the other side took about 45 minutes. It looks daunting but if you have the tools, a jack and jackstands and a great deal of patients, you'll save yourself hundreds$$$$. It's one of those jobs where the parts are under $30 and the labor is insane. JUST DO IT.
#776195
01/04/07 02:08 PM
Thanks for the encouragement. I re-read the instructions and think it just sounds harder than it is... Looks like tools I would need are: jack, jack stands, basic sockets/racthet, pry bar and hammer. Am I missing anything? Now I just need to find a free weekend to do this
[Re: Tygger]
#776196
01/12/07 05:43 PM
What chemical (grease remover) should I use to clean out the old gunk???
[Re: Tygger]
#776197
01/12/07 05:55 PM
I just used carb cleaner. Just wipe out as much grease as you can with a rag, then hose it down with carb cleaner. Worked well for me. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Richard Saylor]
#776198
01/15/07 05:40 AM
If you have auto locking hubs this would be a good time to clean them out and get them working right. Mine were not releasing.
I know this sounds wierd but you'll need a fishing scale to put them back together.
#776199
01/15/07 06:06 AM
Too much grease is as much a problem as too little -- there needs to be a film of grease for the parts to slide. * too little grease and the bits will rust * too much grease and the bits will essentially hydro-lock
There's limited room inside the hub, and if there's too much grease, that grease will block off that room.
Randii
#776200
01/15/07 05:16 PM
Isuzu Moderator
Only if you are repacking the wheel bearings. For changing/repacking the CVs or cleaning/lubing the hubs, the pull-scale is not needed.
Good Luck, Michael
