Re: air care test
[Re: torquemonster]
#776470
01/07/07 01:36 AM
I just got my pajero and am still burning my first tank. Did your truck get better milage after you drove it for a while? Did you just use the Redline or did you use something else to clean the injectors? Thanks Don.
1991 MITSUBISHI PAJERO EXCEED
Re: air care test
[Re: DonM]
#776471
01/07/07 04:51 AM
for the first time use I dumped the whole bottle in at once. it gives it a good initial cleaning and then after that I put about 1/3 or 1/4 of the bottle in each time. its tricky trying to guage 1/4 of the bottle when its glugging upside down haha. a few times I've dumped 1/2 in but no big deal.
Re: air care test
[Re: torquemonster]
#776472
01/10/07 01:41 AM
Be careful adding "cleaners" to the trunk. If the trunk, and fuel lines are really dirty, the cleaner will remove all the garbage thru injectors and could plug them. Some of injectors cleaners are designed to clean only injectors and fuel pump. You just disconnect the fuel line from fuel filter and put it to the botle with cleaner. The engine should work on this botle till it finishes all the cleaner.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5989 MB (Peak: 0.6524 MB) Data Comp: Off Server Time: 2026-06-07 04:14:10 UTCValid HTML 5 and Valid CSS
