99 runner transmission service question. #776801 01/02/07 06:27 PM
Hey Guy's ,
Happy New Year and Happy Motoring to you all!
My 99 runner auto trans fluid and filter is overdue for
change.
Where are you guy's getting your filter /gasket kits from and whats the best fluid. Thanks, kenny S>
Re: 99 runner transmission service question. #776802 01/02/07 06:54 PM
Adam F Offline
Your tranny doesn't have a "filter" per say. It has a metal screen that you can clean out and reinstall. Some manuals will tell you it has a filter, but it does not.
With that said, I would just do a drain and fill. Remove the drain plug, put a container under it to measure how much you took out, and put back in what you took out. Will be probably 3-4 quarts at the most. You can do this a few times over a period of time and call it good.
Not 100 sure on what ATF to use. What does the dipstick say? Thats what I'd use.
97 4R, stock, daily driver
Re: 99 runner transmission service question. [Re: Adam F] #776803 01/02/07 07:00 PM
Adam F Offline
Here's a thread for you
thread
Thanks................ [Re: Adam F] #776804 01/03/07 12:11 AM
Great info .....just sorry I didn't start doing it sooner.
Kenny S>
Re: Thanks................ #776805 01/03/07 06:15 PM
4barrel Offline
Just FYI - Jiffy Lube has a "T-Tech" machine that hooks up to the tranny coolant lines and does a "total" ATF fluid exchange of old to new. "Total" in quotes b/c I've read where even this does not clear the old fluid 100%, but I think this gets as close as possible. Cost including fluid is $99. I bought Amsoil synthetic ATF on my own, and Jiffy Lube used my fluid, and gave me a break on the cost of the exchange. I agree that dropping the pan probably isn't necessary unless you've got a problem, and well, if you've got a tranny problem, my sympathies to you.
1999 SR5 V6 4WD
Addcos, Bilsteins, Detroit Truetrac, Amsoil, etc...
Re: Thanks................ [Re: 4barrel] #776806 01/03/07 06:29 PM
Adam F Offline
Jiffy Lube.....STAY AS FAR AWAY FROM JIFFY LUBE AS POSSIBLE.
There are other places to get a trans flush, just don't let the idiots at Jiffy Lube do it.
Do a search on any forum for Jiffy Lube and you'll see.
Re: Thanks................ [Re: Adam F] #776807 01/03/07 07:07 PM
4barrel Offline
It worked out OK for me - they did the exchange a couple years ago. Watched them pretty close b/c I was worried they'd mess it up.
I had a hard time finding anyone else to do this. Called a bunch of tranny shops. Jiffy Lube is the only one that could / would do it. Do you know of any others?
1999 SR5 V6 4WD
Re: Thanks................ [Re: 4barrel] #776808 01/03/07 09:56 PM
Adam F Offline
There are a few around me, not sure about you. Valvoline, Firestone, Toyota dealer, Meineke, Cottman, Pepboys, and others.
Re: Thanks Adam F. [Re: Adam F] #776809 01/04/07 02:19 AM
That thread did the trick.
I purchased a case of Valvoline ATF and drained 4 out of the pan. Refill with 4 qts
I dropped the front skidplate and pulled the hose from the passenger side of the radiator. Run truck........
4 qts out........4 new in.
4 qts out until it ran cherry red clear ..........4 new in.
I let out an extra 1/2 quart for a total of 12.5 and about 40 bucks. Very easy.....wish I would have done it sooner. Thanks again and thanks to the 4x4wire forum.
Kenny Sharrocks <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Thanks................ [Re: Adam F] #776810 01/04/07 05:51 PM
4barrel Offline
Thanks for the tip - I will check out the other places you mention. I need to have the flush performed again, for reasons unrelated to the prior service. (My radiator blew and the tranny fluid and coolant got mixed together in the tranny. I had it flushed once, but am going to do it again to make sure all the coolant is out of there).
1999 SR5 V6 4WD
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6331 MB (Peak: 0.7530 MB) Data Comp: Off Server Time: 2026-10-30 11:52:40 UTC
