ok, so if you calculate high range, your old tire size is 30 and new tire size is 38, old ratio is 4.2, all you need to keep the same 'feel' is a ratio of 5.3 which is a little higher than 4.9 which is what you can put in but it isn't that far off and when it really counts is when you are fourwheeling which you can then use low range and be better off than you were stock.
No matter what you say, it's just not dooable, AND have a good running truck. On a Gen 1, It's gonna require a 6-8 inch body lift, OR a at LEAST 8-10 inch suspension lift which does not exhist. I don't know about a Gen 2....\
Then EVEN if you could get gearing low enough(which you can't) then you would not have enough power to do anything except move around the driveway. Here are the problems.
#1 Fitment.. Massive lift, and or body removal required
#2 Gearing.. They do not make 7.13's for our trucks. Even if they did, the power required to get the mass of a 38 inch tire moving, and keep it rolling is stupid large. You ever picked up a 38 inch tire? How about even a 35? I wonder how much a 38 inch swamper weighs?
#3 Power.... If you want to stay mitsu, you'd better rob a Fuso Truck <img src="/forums/images/graemlins/smile.gif" alt="" />
6 cylinder deisel. <img src="/forums/images/graemlins/kewl.gif" alt="" />
#4 Strength of drivetrain. Stock drivetrain can't handle much bugger than a 33 reliably. Sure some people run 35's in their Gen1, but..... well..... those trucks don't run very well, or anymore at all.
THE ONLY EXCEPTION to these rules are if you live in Iceland.
It's Just NOT going to happen unless you do the following.
Get something capable of producing 300-350 Ftlbs....Get Axles capable of handling 38's(D60's/Portal/Rockwell).. Install appropriate gear ratios, and THEN bolt your 38's on.
