Page 4 of 5 1 2 3 4 5
Re: Has anyone ever......? [Re: LandRaider] #777340 01/05/07 09:33 PM
sparkem Offline
I bet the 95SR rear 9.25in rear diff with 1.4in 31 spline shafts will stand up to 38s fairly well.
I am running 36s with a 2.4 4banger with 5.29 axle gears, it's not too bad on road.
Re: Has anyone ever......? [Re: Scottie2113] #777341 01/05/07 09:34 PM
LandRaider Offline
For those that are interested, I used the online ratio calculator with the following inputs:
old tire: 30
new tire: 35
old ratio: 4.2 (with t case in High range)
the result is a ratio of 4.9 in the diffs to keep the same overall ratio. So even on the highway with 4.90's in the diffs, you can spin 35's with the exact same overall ratio and feel as stock montero gen II. so instead of changing my entire engine and a whole bunch of other stuff to make a new engine work, all I had to do was put 4.90's in the diffs and even while in high range, I can spin 35's with the EXACT same overall ratio as a stock gen II montero.
scottie
No you can't. The RATIO is gonna be the same. But you're going to have a slower vehicle.
It's prob going to be fine, and you'll be able to do the same stuff you did before, BUT don't think for a second that everything is a wash, and it is going to be the same.
You can reduce the ratio all you want, but there is alot more to the whole system that you are missing. It's not as simple as JUST reducing the gear ratio.
You're not going to have the same acceleration, or decel as before, and you are effectivly going to lose power overall.
Re: Has anyone ever......? [Re: LandRaider] #777342 01/05/07 11:02 PM
TommyM Offline
If the effective ratio is the same, what else is there to overcome?
1) The additional inertia of the heavier tires/wheels
2) Maybe a very small different coefficient of friction -- tire to road friction is small, because it's roughly the same weight vehicle on a bigger tire contact patch (less friction over a bigger area), plus probably a little more internal friction in a bigger piece of rubber, but that can't amount to much.
What am I missing?
90 LWB Montero, 270k, 265/75R16, 16x8 ARE Bajas, Budget Lift, Towbar, Aux Brakes (towed with camper), Jotto Desk, remote oil filter
92 bone stock base model beater
Parting out 4 more
Re: Has anyone ever......? [Re: TommyM] #777343 01/05/07 11:37 PM
Does'nt "Partytruck" run 38s on his GenI? His is a oil-burner, but he did a three inch BL and got them under there.
Link to post with pics
Re: Has anyone ever......? [Re: LandRaider] #777344 01/06/07 01:26 AM
LandRaider Offline
THE ONLY EXCEPTION to these rules are if you live in Iceland.
Possible, but not practical.
38s on IFS?? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Has anyone ever......? [Re: LandRaider] #777345 01/06/07 02:00 AM
Scottie2113 Offline
Look guys, more horsepower would be great, but I just don't feel like going through all the time and money to transplant a new engine when the one I have is enough for me, especially since I am going to have an overall crawl ratio of 15.4!!! Can you say 200 hp stump puller????!!!!! <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
for those that are wondering how i got 15.4:
4.9(diff)X3.15(tcase)=15.4
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Has anyone ever......? [Re: off-roader] #777346 01/06/07 04:13 AM
Baldy Offline
When I had the stock Mitsubishi axles I was running 33" tires and snapping the axles like toothpicks, especially the front.
Re: Has anyone ever......? [Re: Scottie2113] #777347 01/06/07 04:23 AM
don Offline
...uhhhh, usually you would express the final crawl ratio as:
1st gear ratio x tcase low x diff ratio...
(Not trying to sound toooo nit-picky here.)
With a M/T, 50:1 is good, and >100:1 is fantastic, with an A/T 35:1 is good, an >80:1 is fantastic.
So the basic Gen1 A/T = 2.826 x 1.944 x 4.625 = 25.4:1, which is nothing too special.
Hence the usefullness of the 3.15 tcase gears = 2.826 x 3.15 x 4.625 = 41.2:1
On the 4.3 swap with GM A/T and tcase and Mitsu diffs = 3.060 x 2.72 x 4.625 = 38.5:1
The GM tcase can get a 4.0:1 swapped in from TerraLow, and then give me 3.060 x 4.0 x 4.625 = 56.6:1, which starts to get pretty serious crawl.
Adding a 2nd tcase/or crawl box or KluneV underdrive (if you got room) would multiply everything up by those extra gears, which are usually 2.7:1 or 4.0:1, which gets you into the truly excellent crawl ratios!
So my "dream" system would be a 2.7:1 KluneV added to my existing 2.72:1 GM tcase which would give 3.060 x 2.72 x 2.7 x 4.652 = 103.9:1, which would give me a truly excellent final crawl ratio...
But I doubt I'd ever need it.
But fun to do the math, though!
Oddly enough, I've yet to see anyone correct for tire size, though. And that also comes into play here...
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: Has anyone ever......? [Re: don] #777348 01/06/07 04:56 AM
FrankR Offline
Then, to complete the picture, you'd have to consider engine rpm - but what you'd ultimately want to know is how fast (or in this case, how slow) you can go. So - to be on a level playing field, all measured contestants (it is a contest, right?) would have to peg the rpms at the same level - say 650 rpms (to be fair to the A/Ts). Then, of course, the M/T folks would try to slip the clutch... the A/T guys would apply the brakes.... and all would be instantly criticized by the others as cheaters. <img src="/forums/images/graemlins/wink.gif" alt="" />
A low crawl ratio is nice - but in the end, it all boils down to whether or not you can get where you want to go..... or not..... and maybe how you look in the doings.
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Has anyone ever......? [Re: FrankR] #777349 01/06/07 05:22 AM
LRJ4x4 Offline
My 2.6 will turn those tires no problem, down hill both ways in 4 Low, reverse <img src="/forums/images/graemlins/smile.gif" alt="" />
Sawzall offer still stands...you will love it Dewalt 18v <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6475 MB (Peak: 0.7590 MB) Data Comp: Off Server Time: 2026-06-23 00:46:07 UTC
