rear windows not working #777550 01/05/07 12:30 PM
L
lesj Offline OP
The power rear windows on my 01 sportage quit working. The front work fine. Does anyone know what the problem may be?
Re: rear windows not working [Re: lesj] #777551 01/05/07 04:37 PM
Do they work from the drivers console or not work at all? If they do work from the driver and not at each door you've got problems, if they do not work from drivers console but each individually works you have a bad driver's console. More info will help hone in on the issue.
Re: rear windows not working [Re: lesj] #777552 01/05/07 07:09 PM
Lou Offline
AS Chris asked, specify if they refuse working from driver switch, rear switches or both. In the mean time : www.geocities.com/lmp4203/kiasport/pwrwindows2001.jpg
Re: rear windows not working [Re: Lou] #777553 01/06/07 12:16 AM
L
lesj Offline OP
The rear windows do not work at all from all switches. The front work fine.
Re: rear windows not working [Re: lesj] #777554 01/08/07 03:57 PM
Hydra747 Offline
This happened to me a year ago. The rear driverside window was stuck (in the up position thank goodness)! Then after about a couple of months it started to work again. Right now it works fine, and sometimes I'm afraid if I use it cause it may get stuck in the down position. <img src="/forums/images/graemlins/confused.gif" alt="" /> I guess I will really never know what happened regarding the window mystery....
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5999 MB (Peak: 0.6605 MB) Data Comp: Off Server Time: 2026-06-24 11:52:18 UTC
