axle swap
#778009
01/07/07 07:29 AM
Do the Rodeo's and Troopers use the same rear axles? I am looking at an 1991 Trooper and a wrecked 1995 Rodeo... I want to swap the drivetrain from the Rodeo into the Trooper.
Re: axle swap
#778010
01/07/07 07:40 AM
Isuzu Moderator
Nope, the Trooper has an Isuzu 12-bolt and the Rodeo has an D44.
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
Re: axle swap
#778011
01/07/07 08:12 AM
They use the same driveshaft flanges so you can use the rodeo driveshaft on the 12 bolt, assuming its the same length which It should be
94 Rodeo 3+3 lift Red) 95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2 front winch bumper custom rear bumper, Hella 500's 2004 Silverado duramax
Re: axle swap
[Re: 94redrodeo]
#778012
01/08/07 05:44 AM
They use the same driveshaft flanges so you can use the rodeo driveshaft on the 12 bolt, assuming its the same length which It should be Be aware of brake differences, the Rodeos were rear drums, no? Just something to think about, not sure if the e-brake cable will be a bolt on, etc.
Re: axle swap
[Re: Fujisawa_Rob]
#778013
01/08/07 06:06 AM
I think 91-92s, and possibly 2wds have drum brakes. The rest got discs.
Re: axle swap
[Re: Rodeo Guy]
#778014
01/08/07 06:19 AM
I think 91-92s, and possibly 2wds have drum brakes. The rest got discs. Ah...and the 91-92's were the GM 10-bolt IIRC? Good info.
Re: axle swap
[Re: Fujisawa_Rob]
#778015
01/08/07 02:54 PM
That is correct. The only Rodeos to come with drum brakes are the GM 10 bolts and the 98 and up 2wd's had drums.
The 1st gen Rodeo in 2wd may have drums but I've not messed with any 1st gen 2wd's to know.
Joe
Re: axle swap
[Re: Bigpoppax2]
#778016
01/08/07 08:02 PM
90-92 rodeos with 4 whl drv had drums all 4 cyl rodeos have rear drums no matter the year all rodeos 92 >>>>>>>> 2 wd drum brakes thru 2003 all 4wd rodeos 93 >>>>>> 2004 have rear discs JERRY
Re: axle swap
#778017
01/23/07 01:09 AM
I installed a 94 Passport rear in my 90 amigo.Bolted right up,used cable clamps for the e-brake.
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
