Re: Check brake light on [Re: Fleabag] #778315 01/17/07 08:01 PM
Houston Offline
If you don't know the age of your brake fluid, then yeah, your best bet is to flush the system or bled the old fluid out while feeding the reservoir with fresh fluid,[DOT 4]. This way your Great White North vehicle won't suffer any frozen moisture in the brake system[sorry, could resist the old SCTV joke <img src="/forums/images/graemlins/shiner.gif" alt="" />] Water in the brake system is no fun......
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
Re: Check brake light on [Re: Houston] #778316 01/26/07 10:35 PM
Fleabag Offline
I went over a snow mound and when I came down, the front right wheel sprung a brake leak. It looks like it is coming from the connection where the hard line meets the soft. Not good with the snowy roads right now. Going to have it looked at when it dries out in the garage.
Strangers have the best candy
Re: Check brake light on [Re: Fleabag] #778317 01/27/07 01:05 AM
Fleabag Offline
Thank goodness for an amazing service garage. IF anyone here is close to Kitchener, Ontario, go to the Mufflerman on Highland and Westmount. They have done almost all of the work on my truck and have saved me 100's of dollars in pain and suffering!
They were able to cut a new end on the brake line as the coiled up line inside the engine bay was still perfect compared to the corroded part that was exposed in the wheel well. This was where the pin hole leak was.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5995 MB (Peak: 0.6527 MB) Data Comp: Off Server Time: 2026-11-02 07:41:54 UTC
