Check brake light on #778305 01/08/07 07:04 PM
2
2timer Offline OP
The master is full. What needs to be checked?
Thanks
Re: Check brake light on [Re: 2timer] #778306 01/08/07 08:45 PM
Houston Offline
Check all your brake lines and hoses for a tiny leak, even if it seems like non-existent seepage at this point. I think the brake switch in the master cyl. reads "rest" pressure and low fluid too. I had a rear flex hose that didn't really drop the fluid level in the reservoir that much, but weeped or lost just enough pressure to trip the Brake light a few days before the rubber or crimp went all the way.
I refilled the reservoir a few days before the hose went, but still saw the warning light flashing on and off, then on steady until I fixed the hose. Once the hose was replaced, no more Brake Light.
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
Re: Check brake light on [Re: Houston] #778307 01/08/07 08:50 PM
Happy Birthday stony-man Offline
Brake light comes on every time the temperature outside gets below a certain point...it stays on all winter, and then I don't see it again all summer. Been doing that for the last 4 years. If I drive the truck long enough to really get everything warmed up, the light goes out, even in the winter. Weirdness.
- '92 LWB V6 3.0 5 sp
33x10.5 BFG M/Ts & Bouncy seat
- '95 LWB V6 3.0 Auto (Scrapped)
- '05 Montero Limited. Bone stock <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Check brake light on [Re: stony-man] #778308 01/08/07 09:23 PM
52degrees Offline
Unplug the low fluid reed switch on the reservior and see if it goes out.
KG6VNX
Re: Check brake light on [Re: 52degrees] #778309 01/08/07 09:53 PM
sparkem Offline
Also make sure the float thing in the MC is not stuck in the down position.
Re: Check brake light on [Re: sparkem] #778310 01/09/07 07:42 AM
I found out the brake warning light on my Raider has two brightness settings, one for low fluid or no pressure (BRIGHT), the other for issue with the parking brake handle switch (DIM). Just FYI... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Check brake light on [Re: rxinhed] #778311 01/09/07 08:52 AM
torquemonster Offline
I had the IDENTICAL problem on my pajero when I first got it. the problem was the rubber float thing on the inside of the cap must be pushed in and not pulled out. then life is good man.
Re: Check brake light on [Re: torquemonster] #778312 01/09/07 06:49 PM
The cold weather thing is still the float switch in the m/c reservoir, getting hung up because of different rates of contraction in the hinge area of the float between plastic and metal. Brake lube the hinge, working it up and down while doing so. Ditto the rubber air over the fluid seal, which should only protrude to fluid level when installed. It's there to allow volume changes in the reservoir without exposing the fluid to humidity in the ambient air, since the fluid is hygroscopic (likes to suck up water, which will boil when it gets hot enough and you won't have didddly for brakes).
Re: Check brake light on [Re: fasteddy] #778313 01/10/07 07:01 AM
52degrees Offline
Bo?
KG6VNX
Re: Check brake light on [Re: 52degrees] #778314 01/16/07 10:12 PM
Fleabag Offline
I just had this happen... made me feel very uncomfortable. The brake peddle felt solid and was hard to push for a second and then released and I was able to use the brakes. But now the light is staying on. I wondering if there is water moisture in the lines that froze... ew....
Strangers have the best candy
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6379 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-10-27 14:50:26 UTC
