Page 3 of 5 1 2 3 4 5
Re: 10-Bolt Aussie Lockers Available @ Independet4x [Re: islandracer] #778757 02/12/07 10:01 PM
Richard Saylor Offline
What, you left Guam?
Yup, still a few things to get used to but, I think I'm adjusting fairly well... Since I'm driving another Zu I think I'll be ok! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Welcome to Texas! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 10-Bolt Aussie Lockers Available @ Independet4x [Re: Richard Saylor] #778758 02/16/07 04:11 AM
I wonder if one of these would fit in the case of those nonstandard 98 Amigo 4.77's? Seems like a reasonable chance. But then again, this type of locker in a front application probably isnt a real good idea.
Andy
Re: 10-Bolt Aussie Lockers Available @ Independet4x #778759 02/16/07 04:17 AM
Starchild Offline
I was wondering that exact thing <img src="/forums/images/graemlins/confused.gif" alt="" />
I'm getting rid of my 98 Amigo 4.77's, but I also happen to have a spare carrier from the same application. It's worth a try. You can have it Matt, but you have to come to Uwharrie to pick it up <img src="/forums/images/graemlins/lol.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: 10-Bolt Aussie Lockers Available @ Independet4x [Re: Starchild] #778760 02/17/07 04:43 PM
matthew Offline
deal..... <img src="/forums/images/graemlins/smile.gif" alt="" />
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: 10-Bolt Aussie Lockers Available @ Independet4x [Re: matthew] #778761 02/18/07 04:15 AM
muskyamigo Offline
Nope, they won't fit the odd ball 98 carrier. I tried. The opening is physically too small to get the unit in where the spider gears had been.
Heres a pic of the size difference between my '98 Amigo "odd-ball carier" and the '99 Trooper part I used for the install. The difference is as much as it looks.
Trooper on the left, Amigo on the right
One thing I am curious about though. It looks like the SOTF front ends are the same as the non SOTF units, and they just bolted the SOTF unit on to the end of the old housing. anyone know for sure?
-Mike
Mike Walter
'98 Amigo well used
'94 Rodeo in need of help
'99 Ram CTD for hauling feather pillows
'01 unheated shop
Re: 10-Bolt Aussie Lockers Available @ Independet4x [Re: muskyamigo] #778762 02/19/07 01:50 AM
Starchild Offline
Well, it was worth a try. Were you able to use the standard carrier with the gears from the '98?
Still coming to Uwharrie Matt? <img src="/forums/images/graemlins/smile.gif" alt="" />
"SERENITY NOW!"
Re: 10-Bolt Aussie Lockers Available @ Independet4x [Re: Starchild] #778763 02/19/07 03:41 AM
muskyamigo Offline
Honestly, I didn't try. It was easy enough to find a front third member with the correct gears in it, so I use that and all of the parts that came with it (minus the odd TOD pinion flange)
From what I recall, I don't believe the 98 gears fit anything but the 98 third member.
Also I couldn't fit the standard third member in the 98 housing.
oh yeah, the cross shaft was also considerably smaller in the 98 differential.
-Mike
Mike Walter
'98 Amigo well used
'01 unheated shop
Re: 10-Bolt Aussie Lockers Available @ Independet4x [Re: muskyamigo] #778764 03/12/07 03:31 AM
matthew Offline
so where are all the 4x4wire guys who wanted Lockers?????
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
we are about 1/2 way through the production run.......if you want one of these in your rig....GET YOUR ORDER IN!!!
12 bolts are pushing toward production......pretty excited about this one.... we have a good list of names going. Just call to get your name on there if you want the rear locker.
-matt
Re: 10-Bolt Aussie Lockers Available @ Independet4x [Re: matthew] #778765 03/12/07 04:52 AM
chasespeed Offline
Right here, BUT...
The Trooper is MIA, and the ex has the 4wd.. so.. no need...
Chase
Chase
Re: 10-Bolt Aussie Lockers Available @ Independet4x [Re: chasespeed] #778766 03/13/07 12:13 AM
W
Wareagle Offline
Matt: I'm in for a 12 bolt locker. I gave Bansil my welded and picked up an open from Jerry L. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Mark
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6428 MB (Peak: 0.7518 MB) Data Comp: Off Server Time: 2026-10-21 14:32:43 UTC
