rear wheel sticking at complete stops........HELP #778953 01/10/07 09:48 PM
my 1999 tacoma TRD has a problem that occurs randomly. when it comes to a complete stop the driver whell (rear) locks and will only unlock when driven in reverse for a few yards or rev it up and force it forward which results in a jolt and a loud clunk noise from the rear. my e brake cable disengauges just fine...any ideas???
Re: rear wheel sticking at complete stops........HELP #778954 01/10/07 10:13 PM
RichinROA Offline
Are you starting out in 4 or 2?
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
Re: rear wheel sticking at complete stops........HELP [Re: RichinROA] #778955 01/10/07 10:17 PM
when i start it is in 1st. the lock up occurs the split second i come to a stop (but not at every stop)
Re: rear wheel sticking at complete stops........HELP #778956 01/10/07 10:55 PM
RichinROA Offline
Oh- I was asking about 2 or 4 wheel drive.
99 TacoTRD 177K
Re: rear wheel sticking at complete stops........HELP [Re: RichinROA] #778957 01/10/07 11:45 PM
happens in both.......
Re: rear wheel sticking at complete stops........HELP [Re: RichinROA] #778958 01/10/07 11:50 PM
L
lawnmowerman Offline
Gear oil leaking on your brakepads(due to bad axle seal)will cause drum to lock up.Check for greasy mess on the inside of your tire and backing plate.
Re: rear wheel sticking at complete stops........HELP [Re: lawnmowerman] #778959 01/11/07 12:35 AM
no mess back there
Re: rear wheel sticking at complete stops........HELP #778960 01/11/07 01:52 AM
L
Next step is to pull off the wheel and brake drum and take a look!
Re: rear wheel sticking at complete stops........HELP [Re: lawnmowerman] #778961 01/11/07 02:03 AM
what is the chance that the cylinder is to blame but will still act as normal when the wheel is not sticking...understand?...seems like it is a random (semi) problem i am having and doe not occur at every stop.
Re: rear wheel sticking at complete stops........HELP #778962 01/11/07 02:16 AM
john_luttrell Offline
Lawnmowerman gave you the correct answer; pull the wheel and look for contaminated brake shoes. You will find either axle grease or brake fluid on at least one of the shoes.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6235 MB (Peak: 0.7277 MB) Data Comp: Off Server Time: 2026-10-28 00:28:30 UTC
