rear wheel sticking at complete stops........HELP
#778953
01/10/07 09:48 PM
my 1999 tacoma TRD has a problem that occurs randomly. when it comes to a complete stop the driver whell (rear) locks and will only unlock when driven in reverse for a few yards or rev it up and force it forward which results in a jolt and a loud clunk noise from the rear. my e brake cable disengauges just fine...any ideas???
Re: rear wheel sticking at complete stops........HELP
#778954
01/10/07 10:13 PM
Are you starting out in 4 or 2?
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
[Re: RichinROA]
#778955
01/10/07 10:17 PM
when i start it is in 1st. the lock up occurs the split second i come to a stop (but not at every stop)
#778956
01/10/07 10:55 PM
Oh- I was asking about 2 or 4 wheel drive.
99 TacoTRD 177K
[Re: RichinROA]
#778957
01/10/07 11:45 PM
[Re: RichinROA]
#778958
01/10/07 11:50 PM
Gear oil leaking on your brakepads(due to bad axle seal)will cause drum to lock up.Check for greasy mess on the inside of your tire and backing plate.
[Re: lawnmowerman]
#778959
01/11/07 12:35 AM
#778960
01/11/07 01:52 AM
Next step is to pull off the wheel and brake drum and take a look!
[Re: lawnmowerman]
#778961
01/11/07 02:03 AM
what is the chance that the cylinder is to blame but will still act as normal when the wheel is not sticking...understand?...seems like it is a random (semi) problem i am having and doe not occur at every stop.
#778962
01/11/07 02:16 AM
Lawnmowerman gave you the correct answer; pull the wheel and look for contaminated brake shoes. You will find either axle grease or brake fluid on at least one of the shoes.
John Luttrell 2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6235 MB (Peak: 0.7277 MB) Data Comp: Off Server Time: 2026-10-29 21:03:57 UTCValid HTML 5 and Valid CSS
