trany slippage jeep #778971 01/10/07 10:56 PM
jeeperscreepers Offline OP
I was woundering if anyone has experienced any slippage when off roading or on the road, I am having a problem like that where I could go to the mountain and everything is fine come home get in the jeep to go to the store down the street a little ways then I get high rpms and I dont move?
I will cycle through the gears back into drive its an (automatic) and everything is fine? I all ready changed out the trany fluid and filter used mobilone synthetic maybe that was the mistake trany shop said it was okay just use some frictioning agent to help they test drove said it drives great, the problem is intermitten I have only owned the jeep about 7mo. its a 97 straight six. does anyone have any suggestions
thank you. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: trany slippage jeep [Re: jeeperscreepers] #778972 01/10/07 11:12 PM
BigJim Offline
Commonly what you describe is a result of low fluid or a dirty filter.. Go there first..
Re: trany slippage jeep [Re: BigJim] #778973 01/11/07 12:42 AM
Thanks Big Jim, is it still possible that I may have a dirty filter even after changing it only a few months ago? and i will check fluid level. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: trany slippage jeep [Re: jeeperscreepers] #778974 01/11/07 01:02 AM
BigJim Offline
Yep! Has it overheated in the interim?
BJ <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: trany slippage jeep [Re: BigJim] #778975 01/11/07 05:02 AM
No it hasn't overheated to my knowledge, I am not the original owner. 2nd owner the jeep appears to have been well taken care of and some aftermarket parts put on. like a Terraflex 4" lift, 31x11.5x15 bfg muds, k&N intake walker headers magnaflow exhaust and new pipes No oil leaks any where just this occasional slipping.
Re: trany slippage jeep [Re: jeeperscreepers] #778976 01/11/07 07:56 AM
BigJim Offline
I'd be looking at the filter.
Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: trany slippage jeep [Re: BigJim] #778977 01/11/07 09:41 AM
Okay the filter it is I double checked the fluid level looked good however I still wounder if it was wise to use senthetic trany fluid <img src="/forums/images/graemlins/confused.gif" alt="" />but im willing to try anything for a piece of mind you know i dont want to get stuck in the mountains I can only imagine what that could cost <img src="/forums/images/graemlins/scared.gif" alt="" /> anyway thanks for the info this is my first jeep <img src="/forums/images/graemlins/baby.gif" alt="" /> still learning thanks Big Jim.
PHP: 7.4.33 Page Time: 0.048s Queries: 15 (0.023s) Memory: 0.6098 MB (Peak: 0.6876 MB) Data Comp: Off Server Time: 2026-06-25 00:46:03 UTC
