TJ Performance Mods? JET Chip? #779405 01/12/07 04:15 AM
kalaniwavo Offline OP
Just wondering if anyone has any experience with the JET chips. I have a 05 TJ with headers, exhaust, intake. Just wondering what else I can do to squeeze out a little more juice.
Thanks
Nick
Re: TJ Performance Mods? JET Chip? [Re: kalaniwavo] #779406 01/12/07 05:14 AM
BigJim Offline
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: TJ Performance Mods? JET Chip? [Re: BigJim] #779407 01/12/07 07:17 PM
jstritec Offline
Well Nick, i think most of the gear heads around here would say you've already thrown some good money away. The headers, intake and exhaust will get you a few more HP on the top end at the expense of some torque on the bottom end. The Jet chip will fool the computer into running rich and thats about it. (you can achieve the same with a 15 cent resistor in the right spot I have heard)
If you're running big tires and have lost some grunt, you need to re-gear the axles to a lower gear ratio.
If you really want hp, Avenger and Hesco make a supercharger. The 4.0 is solid and reliable and with proper maintenance should go over 250,000 miles, but it was designed for low revving offroad situations. All that crap in the magazines will empty your pocketbook real quick in exchange for 10 hp at 5,000 rpm, and how much time do you spend at the redline?
see also Big Jim's replies to similar questions!
Josh
80 CJ-7.
It runs
Re: TJ Performance Mods? JET Chip? [Re: jstritec] #779408 01/12/07 07:27 PM
BigJim Offline
Josh...You are too kind.. I bet it is much louder too!! He has defeated all the engineering the engineers spent 50 years putting together. It prolly falls on it's face at 1500rpm.
Re: TJ Performance Mods? JET Chip? [Re: BigJim] #779409 01/12/07 07:33 PM
Brown81CJ5 Offline
Not that those mods help at low RPMs, but anything to help make an engine breathe better is not bad. I just would not waste the money on a chip. Chips, IMO, are only worth buying for diesels, where they can give you 100-200 extra lbs of torque at the low end. But even then you have to have the right complimenting parts or the engine will be starved of fuel, or air.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6045 MB (Peak: 0.6693 MB) Data Comp: Off Server Time: 2026-06-14 03:13:11 UTC
