Re: Where is the blower motor resistor? [Re: mlclark] #779881 01/16/07 11:07 PM
Perhaps I should wire it through the high side of the resistor to lower it enough for the 10 amp fuse to work.
Re: Where is the blower motor resistor? #779882 01/17/07 04:51 AM
mlclark Offline
Isuzu Moderator
The high side of the resistor should have no resistance. I.e. it should be feeding the fan a full 12v.
I would think it would be better for you to get another resistor and be done with the problem. Any local parts house should be able to get it or you can give www.stcharlesauto.com and get one from Isuzu.
Michael
Re: Where is the blower motor resistor? [Re: mlclark] #779883 01/17/07 05:45 AM
The resistor checks out fine its the switch that is only letting the fan run on low.
Re: Where is the blower motor resistor? #779884 01/17/07 06:06 AM
mlclark Offline
Isuzu Moderator
Oops, missed that.
Then I modify my suggestion. <img src="/forums/images/graemlins/smile.gif" alt="" /> Get a new switch. Junkyard or St. Charles are your two options.
I am also not sure how you have it currently wired, but that fan should not be pulling over 10 amps.
Michael
Re: Where is the blower motor resistor? [Re: mlclark] #779885 01/22/07 02:41 AM
I had it wired directly to the blower through the feed from the switch. Only one of them is hot so I ran it straight off that.
Since your last post I ran it through the circuit on the resitor with the least resistance. It is holding the 10 amp fuse fine now.
Thanks
1st gen troopers are very rare in the yards around here, I will go with this set up till one turns up.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6043 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-11-02 18:44:58 UTC
