leveling the front of 00 hoe #780088 01/15/07 02:32 AM
I have a stock 00 tahoe 4x4. I want to lift the front to level the truck out. What is the best way to do this with out doing future damage to steering or suspention. I've heard of coil spacers or a torsion key. what are the cons/pros. Is their any other options?
Re: leveling the front of 00 hoe #780089 01/15/07 04:05 AM
52degrees Offline
stock 00 hoe 4x4
<img src="/forums/images/graemlins/confused.gif" alt="" />
KG6VNX
Re: leveling the front of 00 hoe [Re: 52degrees] #780090 01/15/07 04:16 AM
Thats what my wife & friends call her.My big hoe <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: leveling the front of 00 hoe #780091 01/15/07 04:27 AM
52degrees Offline
Crank the torsion bars and go get it aligned. Tell them to ignore the ride height.
KG6VNX
Re: leveling the front of 00 hoe [Re: 52degrees] #780092 01/16/07 02:32 AM
won't this put strain on the cv and tires. Even with realignment. Will this effect off road use. 60%on & 40%off road (light to slighty modified trails)
Want to keep a smooth ride as posible for the long road trips.
Re: leveling the front of 00 hoe #780093 01/16/07 03:44 AM
52degrees Offline
Yeah, it'll strain them a little, but not as much as other things. Besides, it's not like you're telling it to travel outside of it's designed range.
The ride will still be a little more harsh than stock. If you don't like it, buy a real lift and get softride springs.
As far as off-road, no. It shouldn't make any difference.
KG6VNX
Re: leveling the front of 00 hoe [Re: 52degrees] #780094 01/16/07 11:47 AM
thanks for the info.
Re: leveling the front of 00 hoe #780095 01/19/07 08:14 PM
slick8up Offline
just do like I did and drop the back down makes it alot easyer change springs in about 20 mins and your done
94 jeep 3.5 lift 4.56s gears 33/12.5s geolanders mt locked rear warn 8000 and a 4 banger 4 power
PHP: 7.4.33 Page Time: 0.770s Queries: 15 (0.003s) Memory: 0.6139 MB (Peak: 0.6905 MB) Data Comp: Off Server Time: 2026-06-21 01:37:19 UTC
