Page 3 of 4 1 2 3 4
Re: Skid Plates [Re: wsquaredodie] #780785 01/19/07 05:50 AM
CJMT100 Offline OP
Thanks for the advice, I am gonna call that 4x4 place and see what they charge and mock up my own plate out of cardboard to cover past the oil pan a bit.
No one has answered me yet, is it possible to raise the transfercase a bit without a drivetrain lift or something? I mean if its simply botled on I could drill/tap new holes and mount it higher I guess.
Re: Skid Plates [Re: CJMT100] #780786 01/19/07 04:56 PM
adam Offline
It's simply bolted to the transmission, which is simply bolted to the engine. The xmember doesn't support it in thin air so much as support it in line with everything it's attached to, so no, not really without lifting the whole drivetrain.
However, Budbuilt does offer a clocking adapter for a Tacoma that will increase the clearance at the tcase by rotating it, but I can't verify it will work on a T100.
~Adam
Re: Skid Plates [Re: adam] #780787 01/19/07 05:02 PM
Jake97T Offline
these "clocking" setups, wouldnt they interfere with the torsion bracket inside of the frame rail? even if budbuilts system could be adapted...
Re: Skid Plates [Re: Jake97T] #780788 01/19/07 06:28 PM
CJMT100 Offline OP
Well than answers my question, thanks.
Re: Skid Plates [Re: Jake97T] #780789 01/19/07 06:56 PM
adam Offline
Jake, that may be why it's Tacoma listed only. He hasn't built the T100/Tundra page yet, although I'm glad to see the trac-bar for us is a regular offering now.
~Adam
Re: Skid Plates [Re: CJMT100] #780790 01/19/07 10:28 PM
Jake97T Offline
didnt know he was working on T100/Tundra stuff...
Looking forward to updates...
Re: Skid Plates [Re: CJMT100] #780791 01/19/07 10:43 PM
ErikB Offline
Toyota Moderator
Not really because you need to keep the first section of the rear drive shaft in line with the transmission or you will get vibrations. That's why Brew moved the center support bearing up on his. On mine when I had the 2" bodylift, I moved the engine mounts up 2" and the t-case mount up 1", and this pretty much kept that rear shaft in line back to the center support as well.
http://home.4x4wire.com/erik
Re: Skid Plates [Re: CJMT100] #780792 01/22/07 04:25 AM
fishy97t100 Offline
heres a belly skid...still needs some brace in the back and protection for the bolts
[Linked Image] [Linked Image]
1997 T100 SR5 xxcab 4WD 5spd D44, AAM 11.5, dual case
Re: Skid Plates [Re: fishy97t100] #780793 01/22/07 05:19 AM
CJMT100 Offline OP
Very nice fishy, I think I might do such a thing or make a hybrid 2 plated version..
Re: Skid Plates [Re: fishy97t100] #780794 01/22/07 08:15 PM
Honger Offline
Very nice belly skidplate... I like it! <img src="/forums/images/graemlins/kewl.gif" alt="" />
1998 Toyota T100 SR5 ExtraCab 4WD
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6424 MB (Peak: 0.7470 MB) Data Comp: Off Server Time: 2026-06-10 01:10:48 UTC
