how wide is a full width axle? #780814 01/17/07 04:02 AM
roadayo1 Offline OP
I was just wondering how wide a front full size axle? I know there are a lot of differnent widths but give me some idea thanks in advance.
Re: how wide is a full width axle? [Re: roadayo1] #780815 01/17/07 04:05 AM
Rodeo Clown Offline
The full width chevy's are about 67" to 69" WMS-WMS. IIRC
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
Re: how wide is a full width axle? [Re: Rodeo Clown] #780816 01/17/07 04:37 AM
matthew Offline
dodges are usually 67" - like front D44's and D60's
Chevy and fords fronts are "usually" 69"........rear axles.......like vans can be as wide as 72"
to add some isuzu tech <img src="/forums/images/graemlins/smile.gif" alt="" /> you can run 2" wheel spacers on a rear 1996+ trooper 12 bolt rear to make it 67".... AKA full width
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: how wide is a full width axle? [Re: matthew] #780817 01/17/07 02:49 PM
Smiley Offline
The same trick would work on a 1996-97 Rodeo leaf-sprung Dana 44 too.
(It's a bit wider than the earlier Rodeo D-44s)
Six Isuzus, so far... still have three of them.
Re: how wide is a full width axle? [Re: Smiley] #780818 01/18/07 07:10 PM
Baldy Offline
I am running full width axles on my Dodge D-50. Front is a high pinion Dana 44 from a 78 Ford F-150. It is 65" wide from WMS to WMS.
The rear is a Chevy 12 bolt. It's width is 62" wide from WMS to WMS. I run 1 1/2" wheel spacers on the rear to make up the difference.
It all fit under my rig and with fender flares it looks pretty good.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6026 MB (Peak: 0.6671 MB) Data Comp: Off Server Time: 2026-06-06 04:58:14 UTC
