E-code headlamps #780848 01/17/07 08:26 AM
VanillaTHUNDA Offline OP
Performance-wise, how are e-code halogen lamp housings different from DOT ones? The only thing I could drag out of the Hella rep was that DOT is legal and ECE isn't..... <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: E-code headlamps [Re: VanillaTHUNDA] #780849 01/17/07 08:33 AM
4Crawler Offline
E-code has a better, more even beam pattern. You can get DOT housings with sharp low beam cutoffs, like the Hella Vision Plus. More info on the Daniel Stern site:
- http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#MoreInfo
I used to run a set of non-DOT Hellas (not sure if they were e-code or not) back in the '80s and now run a set of DOT Hellas and they seem to be very similar.
One thing to watch for w/ e-code lamps is to not get any made for use in countries that drive on the other side of the road, they won't work in the US.
Re: E-code headlamps [Re: VanillaTHUNDA] #780850 01/18/07 02:34 AM
jasonmt Offline
And depending upon your location E-code lamps are legal for us Canucks...
Re: E-code headlamps [Re: jasonmt] #780851 01/20/07 03:17 AM
babyhuey Offline
I got the autopal ecodes off of ebay.They look stock except they dont have the alignment bumps.Beam is sharp and square,and with the 55/100 bulbs it lights up the night
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6008 MB (Peak: 0.6566 MB) Data Comp: Off Server Time: 2026-06-16 08:29:43 UTC
