windshield washer nozzle #781279 01/18/07 05:45 PM
'ol trigger Offline OP
One of the windshield washer nozzles doesn't spray at all. Washer pump works fine, fluid through the line to the nozzle assembly. I tried working a small piece of wire through the top side of the nozzle but couldn't get it to go all the way through. I assume the nozzle is clogged by something (maybe lime/calcium deposits after all these years?). I would rather not remove the nozzle assembly if possible since other wiring/tubing is connected to it. Any other ideas on how or what to use to clear it?
Thanks,
Jim
Tulsa
'89 two door v6 auto
Re: windshield washer nozzle [Re: 'ol trigger] #781280 01/18/07 05:53 PM
Removing the nozzle is actually pretty easy. I'd do that and throw it in some lime-away or some other calcium deposit disolving fluid for a day or two then check it again. It could also be a tiny rock or something blocking it as well.
Re: windshield washer nozzle [Re: off-roader] #781281 01/18/07 06:55 PM
JacknCoke Offline
how do you remove the lines?
Had an 89 Raider SWB
www.thesurvivalpodcast.com
Re: windshield washer nozzle [Re: off-roader] #781282 01/18/07 06:55 PM
CapnCrunch Offline
Put some compressed air to it. That's happened before on my pickup and compressed air cleared it right out.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: windshield washer nozzle [Re: CapnCrunch] #781283 01/19/07 01:33 AM
89montero Offline
my 89 lwb did the same thing and I couldn't get it to work right so I just bought some nozzle jets and put those one, they each have three little jets so there's 6 streams of fluid being sprayed, works great.
http://rides.webshots.com/photo/2271842990049304464tNBTwe
that's the only pic I have that shows them, you can see the two black things on the hood.
1989 Montero 4dr V6 3.0l
Re: windshield washer nozzle [Re: 89montero] #781284 01/19/07 03:34 PM
JAVYPRO Offline
If lime-away is nt available you can also use some white vinegar.
Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6100 MB (Peak: 0.6805 MB) Data Comp: Off Server Time: 2026-06-21 00:53:13 UTC
