Trooper V6 idle speed #781384 01/18/07 08:58 PM
mthunderwolf Offline OP
I got my trooper back from the shop yesterday after they replaced the worn out CV boot and replaced the o-ring in the distributor that was broken. The mechanic told me he advanced the timing a little so it has a little more "pep" (which it does). Before I took it back to them it was idling around 800. Now it is idling around 1100-1150. What should the stock V6 on a '91 be idling at, should I have him re-adjust the distributor...OR...is there an idle adjustment screw on the TBI?<img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks,
Mark
ThunderWolf
91 Trooper 2.8 v6
86 Trooper 2.3 4cyl
no lift kits... yet!
Re: Trooper V6 idle speed [Re: mthunderwolf] #781385 01/18/07 10:24 PM
F
Fujisawa_Rob Offline
Thanks,
Mark
There is a screw on the TBI to set the "base idle", but you'll need to reset the Idle Air control solenoid before you do it. Do a search - there's an article on S-series.org I think that discusses this. 800 rpm sounds right for the base idle, but when the computer is in control via the IAC, mine idles at about 1100 rpm.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Trooper V6 idle speed [Re: Fujisawa_Rob] #781386 01/19/07 12:46 AM
Maybe I wasn't letting it warm up enough to see what is really going on. It is still pretty chilly up here. I drove into town and after it warmed up it dropped back to the 800 area. <img src="/forums/images/graemlins/scared.gif" alt="" /> . This mechanic told me that it's okay to advance the timing a little up here in the mountains <img src="/forums/images/graemlins/confused.gif" alt="" /> I don't think it's been given very much attention given that fact that I ran thru a whole can of CRC to clean the TBI <img src="/forums/images/graemlins/frown.gif" alt="" />
ThunderWolf
91 Trooper 2.8 v6
86 Trooper 2.3 4cyl
PHP: 7.4.33 Page Time: 2.309s Queries: 15 (0.004s) Memory: 0.5939 MB (Peak: 0.6485 MB) Data Comp: Off Server Time: 2026-06-23 20:02:48 UTC
