sas swap #781438 01/19/07 02:10 AM
94rodeo94trooper Offline OP
i have a 94 trooper want to straight axle it looking for the spec i also want to add have 94 rodeo with 31 dueller mt and love them work for tire store got great deal here is picture of my rodeo at haspen with buddy
Re: sas swap [Re: 94rodeo94trooper] #781439 01/19/07 03:19 AM
strawmyers Offline
Isuzu Moderator
If you search using the following parameters, you'll find gobbs of info:
keywords: +SAS
forums to search: Isuzu forums
date range: newer than 4 years
result format: 200 results to show per page
Check out the Isuzu archives as well. A lot of people have done this swap; but there is no 'set' way to do it or bolt-on kit available. Most go with a 70's Wagoneer D44 and leaf springs; but there are quite a few variations. All kinds of information already out there and ready for reading. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean Strawmyer
Re: sas swap [Re: 94rodeo94trooper] #781440 01/19/07 04:26 AM
spacecab90 Offline
Everything(almost) you ever want to know about SAS
SAS Threads
1990 Isuzu Spacecab, SAS 95% done
'06 Nissan Sentra SE-R Spec V
Re: sas swap [Re: 94rodeo94trooper] #781441 01/20/07 01:56 AM
i am tryin to keep it cheap any direct helpful hints and parts
http://www.tacomaterritory.com/forum/showthread.php?t=43190http://i148.photobucket.com/albums/s13/jerm5591/haspen5.jpg
Re: sas swap [Re: 94rodeo94trooper] #781442 01/20/07 03:21 AM
Starchild Offline
The most common swap uses a Jeep Wagoneer or J-10 front Dana 44 axle (1974-79). The basic parts you need can be found here. You can find the details of the basic spring hangers by searching the above link.
Welcome to the site,
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: sas swap [Re: 94rodeo94trooper] #781443 01/22/07 10:13 PM
anybody in the southwestern ohio are ever done the sas swap
Re: sas swap [Re: 94rodeo94trooper] #781444 01/23/07 12:33 AM
once i change the front to sas do i need to replace the rear and in everyones opinion which is better toyota or jeep axle i can get both at a good price just trying to see which will give better stance and durability
Re: sas swap [Re: 94rodeo94trooper] #781445 01/23/07 12:55 AM
strawmyers Offline
Isuzu Moderator
Coilovers are by far the least cheap option. If you want cheap, 70's Wagoneer D44 and leaf springs from the same vehicle is about as cheap as you can go. A leaf-sprung setup is also the 'easiest' to design because the leaves both locate the axle and act as springs. Using coils, coilovers, or air shocks will require designing and buildin some kind of linked suspension... and that takes a lot more know-how to do correctly. I'd really encourage you to read through as many past threads on this as you can. If you're asking what coilovers entail, then you're a lot of research away from actually building anything. That is not meant as a slam, its just the truth of the matter that this is a big project and spending some hours reading the experiences of those who have come before you can only serve to improve your final product. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I shortened the link spacecab90 posted so the screen wouldn't be so wide; but its definitely an excellent start to your SAS journey: SAS Threads
Sean Strawmyer
Re: sas swap [Re: 94rodeo94trooper] #781446 01/23/07 01:05 AM
strawmyers Offline
Isuzu Moderator
The rear axle will depend on what tire size you are wanting to run. If you are going 1/2 ton stuff (D44) up front, your stock rear axle (Isuzu 12-bolt) will handle anything the front axle will. If you are wanting to run 42's, then its time to move up to 1 ton stuff front and rear.
Sean Strawmyer
Re: sas swap [Re: strawmyers] #781447 01/23/07 01:08 AM
running 35 thornbirds tsl got for free
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6371 MB (Peak: 0.7628 MB) Data Comp: Off Server Time: 2026-07-13 10:46:21 UTC
