Factory Gearing of Rodeo #781516 01/19/07 03:14 AM
A
axledeep Offline OP
I couldn't find this posted anywhere, but I'm assuming Rodeo's came with different gears depending on motor/tranny combo...does anyone have a chart showing what combination came with what. In particular, I'm looking at 95.5 - 97 models. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Factory Gearing of Rodeo [Re: axledeep] #781517 01/19/07 12:30 PM
Rodeo Guy Offline
For 93-97 the gearing was based on tire/wheel package. With oem 225/75/15s (steel wheels), you get 4.10. 245/70/16 (alloys) gets 4.30s. There is one more option available that is rare, I think its 225/75/16 with 4.30s. 2wd and 4 cylinders models got 4.56s.
In 98+, the gearing depended on tranny. Auto= 4.10, Manual= 4.30. Some 4 cylinder and 2wds got 4.77s.
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: Factory Gearing of Rodeo [Re: Rodeo Guy] #781518 01/19/07 03:36 PM
RobG Offline
Re: Factory Gearing of Rodeo [Re: RobG] #781519 01/19/07 03:59 PM
A
axledeep Offline OP
Thanks Much !
Re: Factory Gearing of Rodeo [Re: Rodeo Guy] #781520 01/19/07 05:09 PM
Smiley Offline
(from Rob's website)
96-97:
drum brakes (4 cyl), (4.56 ratio, 41/9 teeth, HC6)
disc brakes (6 cyl), (4.30 ratio, 43/10 teeth, S7C), 3 sensor ABS (sensor in pumpkin)
disc brakes (6 cyl), (4.30 ratio, 43/10 teeth, S7C), 4 sensor ABS (sensors in axle tubes)
Rob's info is correct -- I can confirm that the 1996-97s with V6s got the 4.30s, no matter what tire size they had originally.
Six Isuzus, so far... still have three of them.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6073 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-06-21 09:49:52 UTC
