weird noise?????? #781601 01/19/07 06:35 AM
turkbodiddle Offline OP
weird clanking noise under truck in 1st and 2nd low speed around 10 to 20mph. Sounds like a branch or something stuck up under truck. When I press clutch in the noise goes away. I have been under and have grabbed and rattled cat with no noise and have checked for anything loose. Nothing Will u-joints make this loud like clicking. I dont know how else to discribe it. Almost like someone hitting drumssticks on sheetmetal. help <img src="/forums/images/graemlins/confused.gif" alt="" />
86 toy 33's custom camo paint dura liner black steels 3 inch lift stock motor
Re: weird noise?????? [Re: turkbodiddle] #781602 01/19/07 06:47 AM
myyota Offline
If you have a u-joint thats going bad it can make a clicking or ticking sound. does it happen while in gear or just idleing ?, might be the throw out bearing, just throwing out ideas as to what it could be.
1986 Toyota 4Runner.
Solid Axle Swap, 5'' Lift, 37'' MTR`s, Duel Cases, Detroit Locker Rear, ARB High Pinion Front, 4.88 Gears, Cross Over Steering, Trail Gear Sliders, Addicted Off Road Front Bumper.
Re: weird noise?????? [Re: myyota] #781603 01/19/07 06:50 AM
only does it while Im driving or taking off in 1st 2nd around 20mph of even down shift at same speeds. When clutch is pressed in it goes away and never makes the noise during Idle. I dont feel anything weird while driving its just annoying.
PHP: 7.4.33 Page Time: 0.407s Queries: 15 (0.003s) Memory: 0.5926 MB (Peak: 0.6459 MB) Data Comp: Off Server Time: 2026-06-17 05:32:50 UTC
