Thumping from rear differential
#781638
01/19/07 08:54 PM
I am getting a thump from my rear differential. Is it the ring gear or could it be something else?
2014 FJ
Re: Thumping from rear differential
[Re: dogtoy]
#781639
01/19/07 09:23 PM
Thump? Hmmm...probably not. Sounds more like a ujoint or sticking brakes than gears. Or something in the suspension like a bad shock, worn shackle bushing, etc.
[Re: Adam F]
#781640
01/19/07 10:05 PM
It is only there when power is applied. At coast the thump goes away, the second power is applied the thump starts. I'll tinker around a bit, perhaps I missed something. Thx
2014 FJ
[Re: dogtoy]
#781641
01/19/07 10:39 PM
[Re: ZUK]
#781642
01/19/07 11:43 PM
Ya, that's what I'm thinking. Pretty sure I'm going to have to rip into it and replace it. Zuk you sell stuff right? Where do I go to take a look?
2014 FJ
[Re: dogtoy]
#781643
01/19/07 11:51 PM
Probably going to lock the rear end finally as well. I did not find an aussie locker for the rear of a 91 v6. Do they make it? I need value and dependabilty, as well as ease of installation. I will be doing this myself for the first time and want it done right too. I can rip the 3.0 apart but have only replaced gaskets on the diffs before. I have read up a bit in the search forums any added advice/info is definately welcome.
2014 FJ
[Re: dogtoy]
#781644
01/20/07 12:11 AM
lockrite makes one for the 8" v6 diff. mine works great, super easy to install.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod. -'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
[Re: eightyeight]
#781645
01/20/07 01:15 AM
The '91 V6 4Runner came w/ 8", 4 pinion, 30 spline, 4.11's right?
2014 FJ
[Re: dogtoy]
#781646
01/20/07 05:19 AM
Could also be a axle bearing go south.
"Serenity through Sobriety"
[Re: OOP'S]
#781647
01/20/07 05:37 AM
Or leftover squirrel bits (roadkill) stuck in the wheel.... <img src="/forums/images/graemlins/evil.gif" alt="" />
Question Reality. ----------------------------- '89 Rnr DLX "SR4.5", 32s w/ 5.29 locked f/r blah blah
