Re: Thumping from rear differential
[Re: dogtoy]
#781658
01/25/07 03:46 AM
sent you a pm <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: ZUK]
#781659
01/26/07 12:28 AM
Ring gear it is. Zuk I need you. I will pm you. Give me a call.
2014 FJ
[Re: dogtoy]
#781660
01/26/07 03:19 AM
Ring gear it is. Zuk I need you. I will pm you. Give me a call. I'll post some pics of that ring gear when I get it <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: ZUK]
#781661
01/26/07 08:55 PM
All set Zuk! Ordered 4.88 precision ring & pinion gears, and lockrite from PORC this morning. Just got back from the postoffice; the third is on the way as well. Definately looking forward to the pics. Be about another month or so and I will send the front to you to be geared to match and locked also. No 4wd for a little while, but am curious to see if it may even perform just as well with locked rear instead of open diffs front and rear. <img src="/forums/images/graemlins/zombie.gif" alt="" /> Call if you need anything. <img src="/forums/images/graemlins/kewl.gif" alt="" />
2014 FJ
[Re: dogtoy]
#781662
01/26/07 09:18 PM
but am curious to see if it may even perform just as well with locked rear instead of open diffs front and rear. You'd be amazed. 4WD for steep inclines though.
[Re: ZUK]
#781663
01/28/07 08:19 AM
So was it the ring gear? or could it be the leaf springs and or the rear end tristing around? DO it do it in reverse? Have somebody stand beside your truck and look to see how much the rear end tilts up with pressure
[Re: dogtoy]
#781664
01/28/07 10:36 AM
Ring gear it is. Zuk I need you. I will pm you. Give me a call. Broken tooth.
2014 FJ
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6183 MB (Peak: 0.6967 MB) Data Comp: Off Server Time: 2026-06-13 10:55:14 UTCValid HTML 5 and Valid CSS
