Page 3 of 3 1 2 3
Re: Thumping from rear differential [Re: dogtoy] #781658 01/25/07 03:46 AM
ZUK Offline
sent you a pm <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: Thumping from rear differential [Re: ZUK] #781659 01/26/07 12:28 AM
dogtoy Offline OP
Ring gear it is. Zuk I need you. I will pm you. Give me a call.
2014 FJ
Re: Thumping from rear differential [Re: dogtoy] #781660 01/26/07 03:19 AM
ZUK Offline
I'll post some pics of that ring gear when I get it <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: Thumping from rear differential [Re: ZUK] #781661 01/26/07 08:55 PM
dogtoy Offline OP
All set Zuk! Ordered 4.88 precision ring & pinion gears, and lockrite from PORC this morning. Just got back from the postoffice; the third is on the way as well. Definately looking forward to the pics. Be about another month or so and I will send the front to you to be geared to match and locked also. No 4wd for a little while, but am curious to see if it may even perform just as well with locked rear instead of open diffs front and rear. <img src="/forums/images/graemlins/zombie.gif" alt="" /> Call if you need anything. <img src="/forums/images/graemlins/kewl.gif" alt="" />
2014 FJ
Re: Thumping from rear differential [Re: dogtoy] #781662 01/26/07 09:18 PM
Staceman Offline
You'd be amazed.
4WD for steep inclines though.
Re: Thumping from rear differential [Re: ZUK] #781663 01/28/07 08:19 AM
So was it the ring gear? or could it be the leaf springs and or the rear end tristing around?
DO it do it in reverse?
Have somebody stand beside your truck and look to see how much the rear end tilts up with pressure
Re: Thumping from rear differential [Re: dogtoy] #781664 01/28/07 10:36 AM
dogtoy Offline OP
Broken tooth.
2014 FJ
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 2.560s Queries: 16 (0.004s) Memory: 0.6185 MB (Peak: 0.7132 MB) Data Comp: Off Server Time: 2026-06-12 15:22:53 UTC
