longer wheel studs!
#781723
01/20/07 04:17 AM
help i need to get longer wheels studs for my 4runner...being that all toyota 4x4's are the same i figured i post in here..plus you guys rock..... I had to add small spacers to my hubs to clearence my rims and calipers now i only get 4 turns of the lug on the stud to 80 ft lbs...does anyone know what other studs i could use...so far i have found that the stock knurl is 14.2 and the length is 40mm.. i need about 50mm anyone know anything that would work...i dont care if i need to goto 1/2x20
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
Re: longer wheel studs!
[Re: 4Crawler]
#781725
01/20/07 06:34 AM
hey rodger would you happen to know a part number with the right knurl.... also would grinding down the caliper persay be a bad idea
[Re: willzrunna96]
#781726
01/20/07 06:42 AM
The 610-073 are 2-3/8" long and the knurls press into Toyota hub. Also a 610-144 2-7/8" long. The first works w/ 3/4" spacers on the rea axle and the longer one works on the front w/ 3/4" spacer.
[Re: 4Crawler]
#781727
01/20/07 06:55 AM
YOU ARE THE MAN....Also i found a stud for a rear or a toyota matrix that has the same knurl as stock toyota studs....same m12 1.5 but the shoulder length is considerably longer. by about 15mm do you think this will make a difference if im using 1/4 spacers?
[Re: willzrunna96]
#781728
01/20/07 07:09 AM
[Re: willzrunna96]
#781729
01/20/07 05:45 PM
You would likely have to measure and see. I know with the longer studs I have, I must run the spacer as the shoulder is too long to allow the wheel to fit without the spacer.
PHP: 7.4.33 Page Time: 3.041s Queries: 15 (0.003s) Memory: 0.6220 MB (Peak: 0.7126 MB) Data Comp: Off Server Time: 2026-06-17 16:04:02 UTCValid HTML 5 and Valid CSS
