Interesting winter gas mileage disparity
#781911
01/21/07 05:01 AM
I have always gotten in the low 20s mpg with my truck. This last month it has snowed a ton in Colorado and I haven't had the front end disengaged at all. I have gotten the worst mileage ever in the 10 years that I've had this truck at 17-18mpg. The low temps and resultant high gear oil viscosity mixed with stop-and-go really killed my mileage. Of course that includes the oxygenated winter gasoline and denser cold air. But I have never gotten under 20mpg before even in past winters (but I only had the hubs locked maybe 7 days out of the whole winter). I had been thinking that maybe something was wrong with the engine but I just got 24 mph (highway at around 7k feet) this weekend with front disengaged which is what I get in the summer. I guess cold weather mixed with stop-and-go and having that front end turning all the time really can affect mileage.
1989 reg cab pickup, 22re, 31s, 4.56s, rear ARB, rear OME springs, RS9000s, otherwise stock.
Re: Interesting winter gas mileage disparity
[Re: btn]
#781912
01/21/07 05:41 AM
Oddly enough, I am noticing the exact same thing. My last tank has been dismal, with no apparent reason. Same driving, same everything, as far as I can tell. Usually about 20mpg, and I'd be suprised if I'm getting even 12-15 right now
Kinda sucks. I wonder if there is some bad gas going around in Colorado. I'm in Fort Collins- where are you?
88 Trooper, 2.6 5spd 89 Trooper RS 92 Montero
[Re: 4runnerpilot]
#781913
01/21/07 07:51 AM
I have noticed my milage is lower and a lack of power with gas from certain stations. No snow here B P is very poor gas .I have heard they are mixing stuff in it for environmental reasons ,ethanol or something
oh what a feeling: #1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered #2 86 sr5 4x4 efi parts truck #3 87 2wd parts truck 84 supra yard art
[Re: btn]
#781914
01/21/07 10:00 AM
There are lots of factors that decrease winter fuel economy. If you are like me, you start your engine & then go scrape ice or clean off snow. You get zero MPG while idleing & not moving. Cold engine oil, tranny oil etc increase drag until they warm up, & as you say, accidents & other problems increase time spent with engine running & no movement. The extra drag from using 4WD also factors in, but the mileage drops even in a 2wd rig.
I've been running both for over 20 years up here & I bet I could tell you more or less when the major storms came in by looking at the mileage logs.
Dave
[Re: cktoy]
#781915
01/21/07 03:40 PM
No snow here B P is very poor gas .I have heard they are mixing stuff in it for environmental reasons ,ethanol or something every gas station around here has 10% ethanol in their gas year round. i always thought bp was good gas, but maybe its just my imagination. crown gas on the other hand, it has dirt in it. no joke.
[Re: 87Toy4x4]
#781916
01/21/07 04:38 PM
Two other things that could impact it: 1) If it takes a long time for your truck to come up to temperature.. When the engine is cold, EFI adds more fuel to the mixture.. When really cold, it's actually a lot more fuel.
2) Intake air temp again, more fuel when cold to compensate for dense air.
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#781917
01/21/07 07:48 PM
ya, i went from best of 23.5mpg in early December to current low of 15.5mpg. All this with the same tire pressure/size/ratio/hub unlock. Crazy i tell you! And yes, i live in Quebec and I start engine first for 3mins-ish while i'm scraping snow/ice.
Still, 8mpg differece is too much!
<img src="/forums/images/graemlins/scared.gif" alt="" />
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/ Camper/33x10.5BFG-AT/Open 4:88/1.5"BJS/ +2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
[Re: allochris]
#781918
01/22/07 08:32 AM
Winter fuels are usually good for a 1-3 mpg loss, a 34% loss in mileage is a significant loss. Did you have adrastic drop in temperature?, if not, I would start looking into it, you may have a bad plug, injector or sticking valve, etc. Even letting iot warm up for 5-10 minutes wont consume that much gas to cause a drop like that in mileage.
[Re: Snowtoy]
#781919
01/22/07 04:46 PM
This happens every year to me no matter what car I have had. The best solution is to plug it in over night so the engine isn't a brick in the morning.
(aka suprathepeg, aka Sean) 89 v6 SWB truck "BLACK BEAUTY" EB valves, P&P head 30 over. 95 FZJ80. Lifted. locked and rollin on 33s (my dream machine)
[Re: Snowtoy]
#781920
01/22/07 09:38 PM
Did you have adrastic drop in temperature Only from about 7-8?C (23.5mpg) to -10?C ish (15.5mpg), about 15? - 20?C colder. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
