tj flares on a yj #782130 01/22/07 01:21 AM
How hard is it to put tj flares on a yj and how do you do it. also can you put a 12.5'' wide tire on an 8'' wide rim.
Thanks
Re: tj flares on a yj #782131 01/22/07 07:28 AM
shouldn't be anything to it. You'll just have to cut the rear fenders out a little more with a saws-all or jig saw. Its really your preference. As a general rule you can run tires that are up to 4 inches wider than the wheel so you should be fine.
Re: tj flares on a yj #782132 01/22/07 03:20 PM
bhartwell59 Offline
there's a step by step in the tech archives on this... i plan on doing the same one of these days.
a 12.5" (that's usually a 33" tire) on an 8" wheel is no biggie although some will say you'd need a 10" wide wheel.
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: tj flares on a yj #782133 01/22/07 10:25 PM
magsnubby Offline
Not hard at all. I did '94 TJ awhile back.
Check out:
www.4x4wire.com/jeep/tech/body/tj_flares_yj/
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5907 MB (Peak: 0.6477 MB) Data Comp: Off Server Time: 2026-05-30 03:42:37 UTC
