third members
#782462
01/23/07 03:53 AM
are third members interchangeable front to rear
Re: third members
[Re: kc85]
#782463
01/23/07 04:06 AM
whay year?
they are interchangeable unless you have an IFS front suspension.
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!! 2005 Tundra Quadcab.
Re: third members
[Re: kc85]
#782464
01/23/07 04:06 AM
Re: third members
[Re: 4Crawler]
#782465
01/23/07 04:07 AM
how are they, does't one spin backwards
Re: third members
[Re: kc85]
#782466
01/23/07 04:09 AM
how are they, does't one spin backwards Yep, front diff runs in reverse going forward. Put it in back and it'll run forward.
Re: third members
[Re: 4Crawler]
#782467
01/23/07 04:11 AM
i'm new sorry if i sound stupid, so does one run on the coast side of ring gear, and isn't that weaker
Re: third members
[Re: 4Crawler]
#782469
01/23/07 04:15 AM
last one, why can't modify housing turn third upsidedown and have high pinion, thanks for your answers
Re: third members
[Re: kc85]
#782470
01/23/07 04:59 AM
Firstly, it'll run backwards (in either axle). Secondly, won't oil properly, nothing to sling/pump oil up the the high pinion gear, you'll need to overfill the axle to keep it oiled. More info: http://www.pirate4x4.com/forum/showthread.php?t=545699
Re: third members
[Re: kc85]
#782471
01/24/07 12:41 PM
last one, why can't modify housing turn third upsidedown and have high pinion, thanks for your answers Turning the third over is easy its getting the pinion offset to move to the other side of the ring gear so you can flip the carrier. The casting just wont work due to the pinion offset.
90 Xcab V6 3.0 Rebuilt/Balanced P/P w/OS valves Downey Hdrs,Jacobs Ign 5.29's,Tru Trac+Lockright 4"TG SAS+Rear Kit on 35's (DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />) www.performancecylinderheads.com
