Page 4 of 4 1 2 3 4
Re: UPDATED: Amazingly, horribly bad mileage [Re: Bigpoppax2] #782519 01/30/07 06:47 PM
TatoHead Offline
One thing nobody is talking about is the tire correction factor. You need to increase your miles shown on the odo to what you actually drove. This is because you are getting lied to by the odo seeing as it still thinks you have a stock tire size on.
Correct this and see if your milage numbers don't look somewhat better?
Joe
Good point. Here in Idaho, and in other states I'm sure, they have "speedometer check" zones on the freeway. These zones are 5 miles in length and there is signage at every mile to allow you to calibrate your speedometer. It isn't an exact science; the driver has to "eyeball" the exact instant the vehicle reaches a mileage sign against what the odometer is showing.
I have determined that my '93 is reading slightly low; therefore my MPG should be corrected by about 2% higher.
Good luck
1993 Trooper
"Purple People Eater"
Re: Amazingly, horribly bad mileage [Re: BigHornE] #782520 01/30/07 08:43 PM
Richard Saylor Offline
Well, since I'm running 265s, they're 8.2% larger than stock 245s. So even if I account for the larger tire size, that's still only about 10.5 mpg.
Distance: 177miles
Gallons: 18.2
Adjustment: 1.082
MPG: 10.52274725
Not too good even with the 'larger' tires...
BH
10.5 mpg in town, to me, isn't THAT bad. Not for a vehicle with the aerodynamics of a sheet of plywood held against the wind.
I average around 15-16 mpg highway. When I was driving in town mostly, I'd get roughly 200 miles out of a tank, which is roughly around 10 mpg too.
Another thought here is that if you have factory gears and larger tires, your engine is having to take up the difference and is therefore working harder. Not only are you effectively getting a taller gear ratio, you're also adding mass to boot. All that adds up in more stress placed on the engine. The more stress it has, the more fuel it uses up. If you were to re-gear, you might actually gain better gas mileage (even after adjusting for speedometer error).
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: UPDATED: Amazingly, horribly bad mileage [Re: TatoHead] #782521 01/31/07 03:44 AM
A
all we'll drive Offline
I use the Miata web page. http://www.miata.net/garage/tirecalc.html
My 95 with 265's gets 16.8mpg without converting and 18.0 with. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
1995 Trooper 3.2 single, 5 speed, OME 912's, T-bar crank, G80, 285 M/T's, custom dents, random rust
1999 Trooper 3.5, auto, TOD, K&N, tint (wife's car can't improve it)
1988 Trooper LS 5 speed SOLD
Re: UPDATED: Amazingly, horribly bad mileage [Re: all we'll drive] #782522 01/31/07 04:29 AM
V
VOLTRON Offline
well adding the 11% only adds 22 miles and then its only at 10.5 miles per gallon which is freakin terrible. I know the larger tires and heavier wheels and added weight to the suspension with the add a leafs and plus the added weight of the fullsize spare will effect gas milage but sweet jesus that is bad gas milage. I am one of those people that drives a SUV that gets horrible gas milage. Atleast it has seen tha dirt. :lol
NOT ALL WHO WANDER ARE LOST
Re: UPDATED: Amazingly, horribly bad mileage [Re: Bigpoppax2] #782523 01/31/07 05:02 PM
Van Offline
Being a former Canuc <img src="/forums/images/graemlins/smile.gif" alt="" />, a couple of other items that are of issue:
"Gallon of gas" Canadian Imperial Gallon = 4.546 Liters
U.S. Gallon = 3.785 Liters
Ref: http://en.wikipedia.org/wiki/Canadian_English "Units of Measurement"
Another issue:
Gas Tank Size: http://www.theallineed.com/math/06011804.htm
One more for thought: http://www.fueleconomy.gov/feg/bymodel/1992_Isuzu_Trooper.shtml
Keep in mind the "Canadian Imperial Gallon vs. U.S. Gallon
YOUR mileage may vary. <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.007s) Memory: 0.6172 MB (Peak: 0.7155 MB) Data Comp: Off Server Time: 2026-07-13 15:45:47 UTC
