Engine Life
#783104
01/25/07 03:28 AM
so i have a 96' t100 with the 3.4L in it.(Bone stock for now)i jsut hit 225,000 miles, i burn NO OIL, and NO ANTIFREEZE.also all my major gaskets are sealed tight. head gasket,valve cover, manifold. does anyone know what the expectancy life of an engine like this?
T100_Trucker. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Engine Life
#783105
01/25/07 06:11 AM
Toyota Moderator
Mine is similar, but burns a little bit of oil (not any more than it ever has though). I see no indication that these things aren't going to last another several hundred thousand miles. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Engine Life
#783106
01/25/07 04:53 PM
With proper maintenance and no abuse the 3.4 should go >500K without major component failure.
Jeff 96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: Engine Life
#783107
01/25/07 08:27 PM
i've got 247k miles on mine, but I've got the 3rz-fe.
Re: Engine Life
#783108
01/28/07 06:04 AM
I have almost 200k on mine, bought it with 175k on it. The only thing that bugs me is the oil pressure drops pretty low on the meter when it warms up. It purrs and pulls though.
98 Taco 4WD
Re: Engine Life
#783109
02/03/07 07:02 AM
My original motor died at 156k. It threw a cam threw the front of the head. I beleave it to be because the original owner didn't change the oil very often. But the new motor has run great ever since.
Toyota master
Re: Engine Life
[Re: thecat]
#783110
02/04/07 05:31 AM
Mine just turned 132k, it has develpoed a bit of an oil leak at what seems to be the rear main. also have the tapping of a lifter I suppose should get that done soon. Rich
07 Mercedes GL 450 93 Freightliner FL 70 C/C 8.3 cummins, allison auto 96 Toyota T100 4x4 xtra cab v6 5 spd 05 KZ 41kx2 NV Toy Hauler 14'garage 43'of 5r 04 polaris 500 HO 50th year limited 02 polaris 500 HO 51 willys M38 56 Dj
Re: Engine Life
[Re: RichieRich]
#783111
02/04/07 07:00 AM
Honestly I have about 60k now, its a reman from yota thanks to the PO. But the trans has 189k..
