Re: Break and clutch fluid [Re: thefreqofnature] #783122 01/27/07 01:24 AM
Stevie Offline
Read the top cap of the reservoir! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
'80 4X4 Longbed
Re: Break and clutch fluid [Re: Stevie] #783123 01/27/07 06:27 AM
thefreqofnature Offline OP
And you get 20 year old information...not so smart
thefreqofnature
Re: Break and clutch fluid [Re: thefreqofnature] #783124 01/27/07 08:23 AM
VanillaTHUNDA Offline
Depends on what you consider 20-year old info - standard DOT 3 is still used in most vehicles today. To answer the question put forth, DOT 4 is a synthetic DOT 3 that has a higher boiling point and absorbs slightly less water. Most, depending on the manufacturer, are compatible with DOT 3. DOT 5 is a silicone-base fluid used mainly in motorcycles and very high temp brake systems that is incompatible with DOT 3. Hope this helps <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5992 MB (Peak: 0.6524 MB) Data Comp: Off Server Time: 2026-05-29 23:45:34 UTC
