Re: Break and clutch fluid
[Re: thefreqofnature]
#783122
01/27/07 01:24 AM
Read the top cap of the reservoir! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
'80 4X4 Longbed
[Re: Stevie]
#783123
01/27/07 06:27 AM
Read the top cap of the reservoir! <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> And you get 20 year old information...not so smart
thefreqofnature
#783124
01/27/07 08:23 AM
And you get 20 year old information...not so smart Depends on what you consider 20-year old info - standard DOT 3 is still used in most vehicles today. To answer the question put forth, DOT 4 is a synthetic DOT 3 that has a higher boiling point and absorbs slightly less water. Most, depending on the manufacturer, are compatible with DOT 3. DOT 5 is a silicone-base fluid used mainly in motorcycles and very high temp brake systems that is incompatible with DOT 3. Hope this helps <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6000 MB (Peak: 0.6532 MB) Data Comp: Off Server Time: 2026-06-07 05:03:42 UTCValid HTML 5 and Valid CSS
