Re: auto shutdown #784069 01/30/07 01:31 AM
BigJim Offline
That is a much clearer description...thankyou. My Ford has two temp sensors. One is for the gauge. The other is for the computer to tell it what the coolant temp is. If THAT one goes out the computer is confused and keeps the engine in a too rich condition.
I cannot remember if your engine has two of them or not. I doubt an oxy sensor would cause this problem from low temp.
Someone else on here will have a better answer..perhaps.
Re: auto shutdown [Re: BigJim] #784070 01/30/07 01:38 AM
thank big jim i am greatfull for the help. oh thats a nice buck.
Re: auto shutdown #784071 01/30/07 05:28 AM
Bigbird79 Offline
Pete had posted a link to this ARRC site in the Jeep Talk forum, that is pretty good and has wiring diagrams and everything on it, I wasn't sure how to post a link to his post so here is a link to the site.
http://arrc.epnet.com/autoasp/index.asp?sid=3041639&uid=s9072919.main.autorefctr
Cut and paste that into IE, I looked it has wiring diagrams, and may help ya out.
I was thinking though, if this relay is tripping and cutting the fuel pump off, have you tried jumping the relay to see if it starts, or removing the relay? I would imagine once you can trace out what connects to the relay on the wiring diagram though, it would help too.
Hope this helps.
Sean
Re: auto shutdown [Re: Bigbird79] #784072 02/02/07 02:28 AM
when i say tripping i mean turning on. what do you all think about, that there is moisture in the computer.
Re: auto shutdown #784073 02/02/07 04:46 AM
Bigbird79 Offline
So why not just remove the relay then if it is shutting down the pump?
Re: auto shutdown [Re: Bigbird79] #784074 02/02/07 05:31 PM
BigJim Offline
That rellay is prolly what turns ON the pump! Removed or shorted out and the vehicle will NOT move!
Re: auto shutdown [Re: BigJim] #784075 02/03/07 07:44 AM
Does your ck engine light stay on after it starts? If so have you checked your codes to see what they show?
Re: auto shutdown #784076 02/17/07 01:23 AM
finely fixed it changed out the ecm matts
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6176 MB (Peak: 0.6994 MB) Data Comp: Off Server Time: 2026-07-13 19:41:39 UTC
