My throwout bearing is toast,.... How much???? #784224 01/29/07 03:31 AM
O
Omega Supreme Offline OP
How much should i look to pay? I mean this thing is going to go anytime now. <img src="/forums/images/graemlins/cheers.gif" alt="" /> 87 pickup 22re 5 spd.
Re: My throwout bearing is toast,.... How much???? [Re: Omega Supreme] #784225 01/29/07 03:40 AM
YOTA88 Offline
IIRC, it'll run you bout $20-$30 for the bearing. i think i paid like $37 for a centerforce throwout bearing when i did a clutch job on my rig a couple of years ago. the price could be more by now but i'm sure someone who has done one recently will chime in.
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!!
2005 Tundra Quadcab.
Re: My throwout bearing is toast,.... How much???? [Re: YOTA88] #784226 01/29/07 03:50 AM
O
how much to have someone else do it?
Re: My throwout bearing is toast,.... How much???? [Re: Omega Supreme] #784227 01/29/07 03:52 AM
Stevie Offline
How do you know it's the bearing?
Just curious <img src="/forums/images/graemlins/cyclops.gif" alt="" />.
'80 4X4 Longbed
Re: My throwout bearing is toast,.... How much???? [Re: Stevie] #784228 01/29/07 03:58 AM
O
well an educated guess. It sounds like something rolling around when i am at idle. Push the clutch in and it goes away. When is 1st through 4th its also loud, it sounds like a rumbling. its pretty loud!!!
Re: My throwout bearing is toast,.... How much???? [Re: Omega Supreme] #784229 01/29/07 06:18 AM
dougcl Offline
Hi, this is not likely to be a throwout bearing problem. It is far more likely to be a transmission problem. Provide a more detailed description of the noise. If it sounds like an old roller skate, it likely that the mainshaft bearing is worn. The noise you describe could also be a loose flywheel.
Doug
Portland OR
80 4x4
Re: My throwout bearing is toast,.... How much???? [Re: dougcl] #784230 01/29/07 06:40 AM
O
its a loud rumbling,i really dont know how to explain it. It has gotten worse. I need to take it, i dont know the first thing about trannys. Its the loudest in 1st and second gear. It sounds like rocks in a trash can. The only time it is quite is when it is 4th or 5th or the clutch is in.
Re: My throwout bearing is toast,.... How much???? [Re: Omega Supreme] #784231 01/29/07 06:47 AM
toyrunner Offline
Input bearing is going.I found a good used trans.Replacing it this week. Having someone do it for you and the replacement cost will be substantial.
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: My throwout bearing is toast,.... How much???? [Re: Omega Supreme] #784232 01/29/07 08:32 AM
Davepet Offline
Nope, not likely the throwout bearing, unless the clutch is miadjusted, throw out bearings only spin when the clutch pedal in pushed in.
X2 on the input bearing being the most likely cause.
Dave
Re: My throwout bearing is toast,.... How much???? [Re: toyrunner] #784233 01/29/07 04:50 PM
Frank Torres Offline
This sounds like the Input Shaft Bearing in your tranny.
You may what to check and make sure you have enough fluid.
If it is your tranny you will notice that 5th gear maybe the loudest and 4th gear may be the quietest.
Do a quick search on input shaft bearing or tranny rebuild.
Here is a link to a D.I.Y. rebuild.
Tranny rebuild
Good luck....
1991 FJ 80 Land Cruiser for fun.
1998 GS300 for the wife
1998 GS400 for me
1991 Supra SOLD
1986 4Runner 335k miles-22re EB inside.SOLD
PHP: 7.4.33 Page Time: 6.906s Queries: 16 (0.004s) Memory: 0.6403 MB (Peak: 0.7436 MB) Data Comp: Off Server Time: 2026-05-30 01:29:15 UTC
