TJ electrical gremlins #784426 01/29/07 10:44 PM
CoronaJeeper Offline OP
My Tj did a strange thing last night. I started it, and drove about a mile, and looked down at the dash to find my speedo and tach was sitting at zero, and the red "airbag" idiot light was on. It did this for maybe 2 or 3 miles, then I came to a stop light, and it started working again.
It was super cold, so the heater was on almost full blast, but other than that, nothing else was running. Lights were on (night). Never done it before now.
Anyone ever seen this?
Corona
'98 TJ, 4 cyl., auto
31" AT KO's on rockcrawlers,
custom bumpers, Hellas
2" Teraflex lift, no top,
no doors, no problem.
Re: TJ electrical gremlins [Re: CoronaJeeper] #784427 01/29/07 10:48 PM
RalkClimber Offline
Wow.. i had the exact same problem.. There is a ground behind your passenger side speaker. Check it.. Might have to re-run the wire or just strip and remount.. <img src="/forums/images/graemlins/evil.gif" alt="" />
I went through all of the grounds found on alldatadiy.com, but there is a free site that BigJim has previously posted. Those are just as good. I just wasn't aware of them before i signed up for the alldatadiy site.
Ralk
'97 Jeep Wrangler 2.5L 105k Miles
Recent Replacements: Cam Shaft, Lifters, Push Rods, Distributor, Dist. Cap/button, Plugs, Oil Pump, Oil Sending Unit, Timing Chain/sprokets, and all associated gaskets.
Re: TJ electrical gremlins [Re: RalkClimber] #784428 01/29/07 10:57 PM
Thanks, man. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Was it one of those grounding straps, or an actual wire?
Re: TJ electrical gremlins [Re: CoronaJeeper] #784429 01/30/07 04:26 PM
RalkClimber Offline
Ground wire, but could be a strap. I know they made some changes from '97 to '98.
Ralk
Re: TJ electrical gremlins [Re: CoronaJeeper] #784430 02/01/07 12:04 AM
DBL_DTY97TJ Offline
Mine did the same thing for a while. Then it stopped and hasn't done it for over a year. I never did figure it out, but I did replace the ground ribbon under the hood. (Don't recall that taht fixed it). Post if you figure it out.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: TJ electrical gremlins [Re: CoronaJeeper] #784431 02/01/07 03:04 AM
Sandinie Offline
it could be a simple as your battery cables needing cleaning. That is common and I just reaired a jeep doing the same thing(bad battery end) ALSO...battery may have been frozen,,,dont laugh, it happens.
PHP: 7.4.33 Page Time: 6.873s Queries: 15 (0.003s) Memory: 0.6086 MB (Peak: 0.6781 MB) Data Comp: Off Server Time: 2026-06-06 10:22:17 UTC
