Page 2 of 3 1 2 3
Re: Oil Cooler Lines [Re: dwehbie] #784722 01/31/07 04:18 AM
52degrees Offline
You guys are all making it too complicated.
Just take the hose assemblies off and carefully cut the "mushroom" part of the hose crimp off. The hose will almost fall off the fitting. You'll find that the fitting is already barbed for a new hose. Take that to your local NAPA and have them sell you about 4 feet of matching sized oil resistant hose, lube well, slip over the barb (not easy) and put a couple new clamps on each end.
That's it! I think it cost me $8.00 to do both of mine. Hasn't leaked a drop since.
KG6VNX
Re: Oil Cooler Lines [Re: 52degrees] #784723 01/31/07 04:54 AM
Oil cooler from my StarQuest swap is the banjo ends with tranny hose and double FI clamps at all four ends. That was two years ago now and ~7k miles. I may have but a little flare on as well, can't remember now.
In my case there was no off the shelf pre-bent option, so I did the flex route on the cheap. Seems to be solid so far
Re: Oil Cooler Lines [Re: MontyMcV] #784724 01/31/07 05:09 AM
I sweated and rebent and sweated and rebent my StarQuest lines until they broke, then I cut off the crimp, and put on oil hose with single really good hose clamps and put a split piece of raditor hose over the oil hose pair where they went thru the core support. No permanent dust spots anywhere means no oil leaks....
Re: Oil Cooler Lines [Re: fasteddy] #784725 01/31/07 05:46 AM
Ditto that on the sleave piece going through the front. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Oil Cooler Lines [Re: DirtyOldTown] #784726 01/31/07 05:55 AM
TobyB Offline
I've had 'em leak at the banjo when they were disturbed-
new washers helped a lot, but one still oozes.
Rust prevention, I say!
t
'89 V6 4dr- '4- Doris'
Re: Oil Cooler Lines [Re: 52degrees] #784727 01/31/07 07:00 AM
DirtyOldTown Offline OP
That is right up my alley.
'91 LWB, 31x10.5s, KYBs, A/T "I look like Robert De Niro, I drive a Mitsubishi Pajero" - Billy Bragg (not the original lyrics, but that's how he sang it when I saw him in Dublin in '04)
Re: Oil Cooler Lines [Re: DirtyOldTown] #784728 01/31/07 07:20 AM
52degrees Offline
KG6VNX
Re: Oil Cooler Lines [Re: 52degrees] #784729 01/31/07 11:30 AM
sparkem Offline
I plan on doing that. Just wanted to make it drivable while the hoses were off.
Re: Oil Cooler Lines [Re: MontyMcV] #784730 01/31/07 06:37 PM
dadrab Offline
This is exactly what I did with a piece of radiator hose for padding through the radiator support - much like Eddy.
I have no metal lines at all left. I just hacked off the metal line ends about two inches from the banjo fitting, flaired it a little and clamped on power steering hose of the same (relative) size. Come to think of it, I didn't even use FI clamps on the hoses. Just the regular old worm gear variety.
Over 15,000 miles now and no leaks.
I also bought a short sack full of those copper washers for the banjo fittings. If I take off a line, I replace the washers.
with awesome audio.
Re: Oil Cooler Lines [Re: dadrab] #784731 01/31/07 10:35 PM
sparkem Offline
That is a good idea, I might just cut the metal lines.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6435 MB (Peak: 0.7513 MB) Data Comp: Off Server Time: 2026-06-20 19:00:40 UTC
