Page 3 of 3 1 2 3
Re: Oil Cooler Lines [Re: 52degrees] #784732 02/07/07 04:43 AM
DirtyOldTown Offline OP
I just did the NAPA fix on my lines (finally!) and it was cheap and easy. Everything still fits exactly as it did before. I used A/T hose and FI clamps, and I replaced the banjo washers. Cost about ten bucks. Hardest part was shoving the A/T hose over the flare.
'91 LWB, 31x10.5s, KYBs, A/T "I look like Robert De Niro, I drive a Mitsubishi Pajero" - Billy Bragg (not the original lyrics, but that's how he sang it when I saw him in Dublin in '04)
Re: Oil Cooler Lines [Re: DirtyOldTown] #784733 02/07/07 04:46 AM
sparkem Offline
I just tried that too. I cut the lines, not the clamp part. I cut the inside of the AT line which let the pressure get to the outer line. It burst the outside of the line. I was in town, so I cut the line past the split and put it back on. Holding for 250 miles so far. I am putting some used Mitsu lines on when they get here.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 2.167s Queries: 16 (0.004s) Memory: 0.5945 MB (Peak: 0.6594 MB) Data Comp: Off Server Time: 2026-06-17 07:17:02 UTC
