Clutch not engaging until very bottom of clutch pedal? #784734 01/30/07 01:43 PM
Y
yota89 Offline OP
Little history first, Dad bought this truck 90 model v6 4x4, clutch always seemed a little funny. This happened before so I used My ("one man bleeder" hose hanging in glass jar filled with brake fuild to keep air from entering system) and had lots of problems. Seemed like tons of air was coming out, and eventually the pedal just stayed on the floor. I ended up having to crack the hose loose at the clutch master cylinder, bleed it out and then work my way back down to the slave cylinder. Managed to make it work and have constant fluid coming out of the slave cylinder, but the pedal still wasnt building pressure like it should. And now 2 months later, Its back to the very end of the stroke again (like the last inch of travel you can change gears. My question is how do you determine wether its the master cylinder or the slave cylinder?
Thanks
89 yota pickup
22RE 261C cam
Tanny / engine rebuilt after 256K
Head machined to RV street spec(EB's)
Re: Clutch not engaging until very bottom of clutch pedal? [Re: yota89] #784735 01/30/07 04:00 PM
OOP'S Offline
I always replace them both along with the rubber hose and I use only OEM.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Clutch not engaging until very bottom of clutch pedal? [Re: OOP'S] #784736 01/30/07 04:11 PM
ErikB Offline
Toyota Moderator
I agree with replacing both and using OEM. I've never had a problem with the line though.
And simple gravity bleeding seems to work pretty well on the clutch stuff. smile
http://home.4x4wire.com/erik
Re: Clutch not engaging until very bottom of clutch pedal? [Re: ErikB] #784737 01/30/07 07:39 PM
Y
yota89 Offline OP
Well the guy he bought it from said he replaced both of them, and they do have a real clean brite aluminum look to them. Do you think one of them could have gone bad already. Whats the best way to bleed the master cylinder? When I press the clutch pedal alot and get out and look into the reservoir I can see lots of little bubbles floating. they seem to come from the bottom of the reservoir and float to the top, Is this normal?
Thanks
89 yota pickup
22RE 261C cam
Re: Clutch not engaging until very bottom of clutch pedal? [Re: yota89] #784738 01/31/07 08:14 PM
bloodbath4runner Offline
<img src="/forums/images/graemlins/scared.gif" alt="" />
No. The FSM stickied at the top should point you in the right direction for finding the bleeder valve.
You know you're in for a rough night at sea when the barometer does this:
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6065 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-06-13 01:08:51 UTC
