Page 5 of 7 1 2 3 4 5 6 7
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: kewlynx] #785066 03/18/07 07:23 PM
A
allochris Offline OP
just checking in. i've been working a lot on the project over the last couple days full-time at my buddy's garage, trying to add all the finishing touches to the flat deck.
I'll let the photos do the talk.
My buddy's recent purchase: 90 x-cab + an EXPENSIVE pop-top roof tent!!! Did I mention expensive btw???
Me:
Deep cycle Battery tray:
Spare Gas Storage with the stock gas door key lock:
How about a 6 wheel drive toyota!
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: allochris] #785067 03/19/07 06:18 PM
A
Rear bumper with hi-lift mount with full-size 33x9.5 spare:
Deck config.:
This is about a 800-900lbs load sitting on the deck. Ride height doesn't look too bad!
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: allochris] #785068 03/20/07 02:09 AM
kewlynx Offline
Lookin' good! You might want to pop by an RV or marine shop and get yourself a plastic top for protecting the battery posts from shorting on anything, provided you've got clearance. A thought.
**ubi apis- ibi salus**
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: kewlynx] #785069 03/20/07 10:22 PM
A
Got around to rivet the skins on today.
Passenger gas storage:
Driver-side straps storage:
Still figuring out how to make the rear milk crate slide-out sideway:
Rear Bumper:
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: allochris] #785070 03/21/07 08:07 PM
Red_Chili Offline
Toyota Section Staffer
1. Is it possible to wire 2 100amp solenoid in parallel to handle the load of a single 200amp solenoid?
No. You will wire it up and it will work, but the very second one set of contacts gets a bit ohmic, most of the current goes through the other solenoid. Not good. At full load one will poof, followed in short order by the other.
You can get 200A solenoids cheap enough, Google is your friend.
-Bill
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: Red_Chili] #785071 03/22/07 02:12 AM
A
Thanks Bill. Right now the dual batteries system is hooked up together with one cheap 80amps continuous solenoid. As I'll need more accessories amp draws when the camper is done, I'll look into those 200A solenoid if needed.
Progress today: a bike rack!
[Linked Image] <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: allochris] #785072 03/22/07 09:11 AM
A
I weighted myself yesterday at 4200lbs with gas tank almost full, pickup box, spare tire, 2 people (300lbs) and stuff (100lbs) in the truck yesterday. That should work out to about 3800lbs curb weight, box/gas/spare included, minus 2 people & stuff.
I weighted myself again yesterday on the way back from skiing at 4312lbs (2365 front/1947 rear), with 2 people (300lbs), 50lbs ski gear, half full gas tank, spare. So I assume my new vehicle weight with spare & full tank is now around: 4312 - 300 - 50 + 35 = 3997 lbs.
So I guess the combo of my flatdeck/hi-lift/full size spare is about 200lbs heavier! <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: allochris] #785073 03/22/07 04:07 PM
IceBlueT Offline
what does the truck weigh stock with a full bed?
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: allochris] #785074 03/22/07 05:58 PM
A
Oh I forgot that I also have a second deep cycle battery mounted on the vehicle too.
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: IceBlueT] #785075 03/22/07 06:01 PM
A
For my truck, (b4 the flatdeck) with stock bed, I weighted at 4200lbs with gas tank almost full, pickup box, spare tire, 2 people (300lbs) and stuff (100lbs) in the truck yesterday. That should work out to about 3800lbs curb weight, box/gas/spare included, minus 2 people & stuff.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6463 MB (Peak: 0.7569 MB) Data Comp: Off Server Time: 2026-07-09 17:40:43 UTC
