Page 4 of 7 1 2 3 4 5 6 7
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: Snowtoy] #785056 02/26/07 05:13 PM
Wing_Nut_OOA Offline
if stock on your truck you had one bulb for tail and brake and a seperate bulb for blinker then you will have too add another light or get a trailer light converter.
Hoppy makes them and some others. you can get them at any major (or minor) parts store or trailer store.
you can probably even get them at U-Haul
they are easy to wire in and will let you run your single light
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: Snowtoy] #785057 02/26/07 06:56 PM
A
allochris Offline OP
Ha, you are right on the bet. I've shorted my wires while connecting the tail lights & burn my 10A gauge fuse. No wonder why I couldn't get my backup light turn on! <img src="/forums/images/graemlins/ignore.gif" alt="" />
Trailer light converter? Wait, that will work? I have one sitting... Problem is that I don't know how to properly wire it up. Mine has 4 connections at the plug type. What colour is what? Where can I find a trailer converter wiring diagram on the net?
Anyway, here is the collection of the parts.
(I also went to Nida-core in Barrie, Canada and got a sheet of 4x8 of 16mm plain for $69usd! This honeycomb sheet is pretty neat. I will epoxy an AL sheet on the top and a 3mm sheet of laminated plywood on the bottom. This will go for the roof top.)
Speaking of epoxy, where can I get big cheap, big quantity, good epoxy/resin? <img src="/forums/images/graemlins/kewl.gif" alt="" />
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: allochris] #785058 02/26/07 10:20 PM
you could do a google search to try and come up with a wiring diagram.
it should say on your little converter box though.
if you dont find anything i'll do another search later.
but you know how it goes.
lunch time's over <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: Wing_Nut_OOA] #785059 02/27/07 05:23 PM
here's a few pictures of some different trailer light converters.
most say on them what wires go where.
rule of thumb.
green is right turn
yellow is left turn
brown is tail
white is ground
normally the brake light is the same as the blinker and it will just send juice through those green and yellow wires.
in order to combine your seperate blinker and tail you will need to use one of these
on one side there are either
A: all wires
B: just the green and yellow.
on the recieving end you will notice that there is one extra wire.
a red one.
this can be any odd color but in this case it is red.
you hook your brake light on the truck side to the red wire and the blinkers to the green and yellow and it combines it in the box
you will need to mount the box on one side of the truck
(preferably the side that the wires are coming down frame)
and run one wire, normally the green one, over to the right side of the truck for the right blinker/brake.
pretty simple really.
you would probably be able to figure it out without me wasting my time typing this! but hey its fun right? <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: Wing_Nut_OOA] #785060 03/03/07 06:52 AM
A
Thanks a lot for the trailer wiring. I've figure it out eventually and then realize that the electronic inside my converter box doesn't work... <img src="/forums/images/graemlins/angry.gif" alt="" />
Anyway, I gave up on fixing it & am going with a second pair of lights option.
Just made this tonight, a plate with tail & backup light mounted for the rear bumper i'm going to make soon (although i still can't figure out how i should make the bumper...)
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: allochris] #785061 03/06/07 07:47 PM
toowacky Offline
Here's another build-up on Yotatech that I've been following, might be able to get some good ideas there for your fab work/planning...
1st Gen 4Runner Expedition conversion
Tom
1988 4Runner 22R-E W56
1989 4Runner 22R-E A340
1995.5 Rodeo 3.2L 5spd
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: toowacky] #785062 03/08/07 12:31 AM
A
Thanks, i've been following on that too.
Anyway, i started cutting the camper's frame lately. Ya, working with aluminium is really fun! Hands are SO much cleaner than steel! (except that it's -15?c outside!)
Question, what's the downside of using a 4.5" zipdisc (hand grinder) on notching aluminium tubing, at areas that are subject to tig welding?
Base of poptop roof:
Frame structure:
[Linked Image] <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: allochris] #785063 03/08/07 12:33 AM
why dont you hurry up and get this thing finished!
sheesh!
i want to see the finished project already!
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: Wing_Nut_OOA] #785064 03/08/07 12:41 AM
A
sheesh!
cause i'm taking 5 university courses & working as well! <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: 70"x84" Flat Deck + Pop-top Camper Build-up!!! [Re: Wing_Nut_OOA] #785065 03/08/07 03:13 AM
kewlynx Offline
It's called a project for a reason, otherwise it would be called a job! <img src="/forums/images/graemlins/smile.gif" alt="" />
Nice layout so far; keep it comin'.
I see on the SuperCamper blog the salvage has begun.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 4.862s Queries: 16 (0.005s) Memory: 0.6523 MB (Peak: 0.7769 MB) Data Comp: Off Server Time: 2026-05-25 21:50:49 UTC
