fast idle/uneven idle
#785813
02/03/07 01:27 AM
Got a rebuilt engine installed by a shop. I expect they put the vacuum hoses on incorrectly, because when I picked it up one hose looped on top of the valve cover with almost a foot of slack. When I brought it in for the 500 mile check I pointed that out, but I suspect they just cut it off because they complained that the under hood hose diagram was fuzzy. Anyway, the engine idles too fast, and after about 10 minutes from a cold start the idle rises and falls for a while. > How can I check the vacuum hoses? > What is causing the idle to vary? Any wisdom would be appreciated! Thanks Mark
'87 4Runner with factory alloy wheels, 225X15 tires, 4banger and 5spd, 26 mpg @60-62 mph, 225k
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5813 MB (Peak: 0.6214 MB) Data Comp: Off Server Time: 2026-06-22 15:13:06 UTCValid HTML 5 and Valid CSS
