Wheel center caps
#786391
02/04/07 03:21 PM
I have 99 TOD Trooper, and I was wondering why my front center caps on my wheels are so much longer than the back. The obvious answer would be that the hubs stick out in the front, but I see other troopers that appear to be my same year model (98-99) with 4 equal caps, the short ones. Does a TOD hub stick out like a locking/autolocking hub? Thanks.
Re: Wheel center caps
[Re: Airtight]
#786392
02/04/07 04:38 PM
Not all 2nd generation Troopers were four wheel drive.
Ones without four wheel drive don't need the longer caps in front to cover the hubs.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake 1989 Trooper 2.6 auto 1989 I-Mark RS DOHC 1.6 1991 Stylus XS DOHC 1.8
[Re: litnin]
#786393
02/04/07 05:14 PM
I'm sorry, I meant to put in my post that I've seen them with the TOD sticker on the back window, and all short caps. Unless someone is just faking with a sticker.
[Re: Airtight]
#786394
02/09/07 11:00 AM
As long as you do not have locking hubs, auto or manual, just have the plate that bolts up in place of the hubs for shift on the fly and track on demand, you should be able to put short caps on the front.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6008 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-05-27 16:11:26 UTCValid HTML 5 and Valid CSS
