Re: 87 Raider 2.6L Still sluggish [Re: fasteddy] #786571 02/06/07 09:24 PM
MotoXman Offline OP
Ok, I just checked the timing and here is what i have:
7 Deg BTDC @ 0 Inches/HG with vacuum adv hose plugged and dizzy capped
VAC Advance check:
23 Deg BTDC @ 12 Inches/Hg with vacuum gauge/pump
12 Deg BTDC @ 6 Inches/Hg with vacuum gauge/pump
Centrif Advance:
16 Deg BTDC @ 2800 RPM.
I also sprayed some more carb cleaner along the intake mani and carb base plate and i do get a slight stumble when spraying it at the intake manifold right by the mech fuel pump. I also removed the hose from the out end of the filter and had a steady stream coming out of it from the gas tank being pressurized. I havent done the accel pump check yet to see if it is starving. Also i only have a vacuum pump in inches/Hg not Lbs/Hg. I am also hearing the hydro lifters ticking sometimes when i rev it up to around the 2800 RPM range but no all the time. I am thinking about just replacing the head with a clearwater head if i find a crack when doing the intake manifold gasket this coming weekend. What do you guys think so far? <img src="/forums/images/graemlins/patriot.gif" alt="" />
87 Dodge Raider M/T 2.6L, Clearwater Head, Pacesetter Header, Weber Carb, Still working on it!
Re: 87 Raider 2.6L Still sluggish [Re: MotoXman] #786572 02/11/07 01:47 AM
MotoXman Offline OP
Ok guys, I got the engine tore down to the block now. After pulling the head i realized that the 2 of the intake valves had a whole lot of carbon on them. The hyd lifters were making a lot of noise lately and i guess my comression loss was due to the int valves not seating properly. I also found out that this thing has a BSE kit installed already and i see cross hatch marks on all the cylinders still. Regardless i am still going to inside mic the bore to make sure it is good before i put the head on. I am also going to replace the chain and gears while im in there. The next main question i have is: Should i order the clearwater head with the mechanical rockers or the hydraulic one? Will the mech rocker head work just fine? I dont mind adjusting them every so often.
Re: 87 Raider 2.6L Still sluggish [Re: MotoXman] #786573 02/11/07 02:05 AM
LRJ4x4 Offline
If you don't mind adjusting go ahead, the hydraulic work just fine for me.
Re: 87 Raider 2.6L Still sluggish [Re: LRJ4x4] #786574 02/11/07 02:36 AM
MotoXman Offline OP
Thanks for the input. Is there a casting number they need or can i just order one on the site now with the mech rockers?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6088 MB (Peak: 0.6655 MB) Data Comp: Off Server Time: 2026-06-20 15:32:48 UTC
