Re: Vibration - Wheels, Tires, Axles [Re: 4Crawler] #786701 02/10/07 12:03 AM
bodo Offline
I bet it's your axleshaft even if you never jump it. They should have been able to see a bent wheel on the balancing machine.
I bet if you jack it up like 4crawler said you'll see it wobble. Try swapping the axle to the other side and see if it follows.
Vibration - Possible diff bearing? [Re: bodo] #786702 02/14/07 05:02 AM
P
Pyroboy Offline OP
Thanks for the ideas. I just got in from running it on axle stands and I think it might be a differential bearing. Everything seems to be running straight, wheels, tires, etc. and the guys that checked the tires said the wheel bearings were good. Also, that would explain why it happened with the rear driveshaft out and why it's worse under load.
When I let it run on stands with both wheels turning and tightened up one side of the e-brake, it made a light growling sound as the power switched to the free wheel. Even with the motor off and in netral, There's quite a bit of rotational 'slop' in the pinion before the wheels start to turn. Any thoughts? The rear end has always been a bit noisy but could an out-of-whack bearing create the vibration? It's pretty harsh around 25-30 mph and seems to be getting gradually worse.
What's a diff rebuild worth?
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5949 MB (Peak: 0.6434 MB) Data Comp: Off Server Time: 2026-05-30 02:09:44 UTC
