UPDATE:Need advise on how to tell the shop they did it wrong #786765 02/05/07 11:52 PM
bloodbath4runner Offline OP
<img src="/forums/images/graemlins/angry.gif" alt="" />
original post
We got some snow, so I had to hold off on going over there. Since the original post, the runner starting pulling to the left when hitting the brakes. So, they freaking tell me that I have a front-LEFT brake problem. wtf????!!!! <img src="/forums/images/graemlins/angry.gif" alt="" /> Says my front left rotor "needs attention".
How in the hell do bad brakes on the left cause you to pull to the left - should pull to the right.
The actual mechanic wasn't there, this was relayed to me 2nd hand by a guy who apparently works there but is not a mechanic... Whatever. I guess I learnt my lesson 'bout paying someone else to work on my rig.
I'm not necessarily doubting that my rotors may be getting thin after 200k, but I seem to see a pattern of missing the real problem.
EDIT: only pulls when hitting the brakes
You know you're in for a rough night at sea when the barometer does this:
Re: UPDATE:Need advise on how to tell the shop they did it wrong [Re: bloodbath4runner] #786766 02/06/07 06:26 AM
dcg9381 Offline
I sticking caliperon the left would make you pull to the left.
Brakes aren't rocket science, they require normal tools, and the willingness to do it right, IE turn or replace rotors...
22REturbo.net
1988 4Runner
Re: UPDATE:Need advise on how to tell the shop they did it wrong [Re: dcg9381] #786767 02/06/07 02:33 PM
I'll definitely turn or replace them if they need it. If the caliper was sticking, wouldn't it pull all the time, not just when I hit the brake?
Re: UPDATE:Need advise on how to tell the shop they did it wrong [Re: bloodbath4runner] #786768 02/06/07 03:21 PM
cktoy Offline
did you ever bleed them properly(not the shop ,you)?new brake parts are pretty cheap and easy to install
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: UPDATE:Need advise on how to tell the shop they did it wrong [Re: cktoy] #786769 02/06/07 04:12 PM
No, I haven't had anytime. I hoped to convince the shop to make it right, but now I'll have to make the time.
Re: UPDATE:Need advise on how to tell the shop they did it wrong [Re: bloodbath4runner] #786770 02/07/07 09:16 PM
Shannons_v8toy Offline
thoughts and personal trials i had breaks pulling befor i up graded my fron calipers and rotors and found it to be a sticky caliper on the right that coused it to pull to the left cuz >>the right caliper sticky and would not clamp rotor with same force as the left side couseing left side to break harder than right test it by having friends wife ect >>>slowly apply break wile u look at bolth removed calipers and see if one moves easyer than the other then put block of wood in between caliper that moves easy and see how much presure it takes to move sticky caliper all with engine off so it can be felt for real and so u can tell helper when to stop ect . hope this helps shannon
ps. loaded calipers are cheap in cal about 80 a piece cheap stopping insurance hit me up pm if u need more asistance or would like to know more about my upgrades experiance !
Shannon 84 toy 7"lift 35"tires 4.88gears det. lockers 320hp smallblock chevy th350 auto trans on baurd air snorkle on baurd welder 8000lb winch custom rear bumber nerf bars
PHP: 7.4.33 Page Time: 1.600s Queries: 15 (0.008s) Memory: 0.6107 MB (Peak: 0.6806 MB) Data Comp: Off Server Time: 2026-11-15 05:20:39 UTC
